Cardboardcat15 Posted October 7, 2011 Report Posted October 7, 2011 How should I go about doing this? I've had a cutout of MDF acting as the false floor in my trunk, but it hasn't been anchored down yet (Yeah, I know, bad). I figure I would just have to do something like bolts long enough to go through the wood and floor, and then a nut at the end to keep in place. I don't really know the names of screws/nuts/bolts and things like that, so bear with me. Also what kind of drill bit should I use to get through the metal of my car? Thanks for any and all help. I really want to get this floor down and in place so I can find a place to mount my amp. Thanks! My Channel on YouTube. Check it out for cinematic-style Car Audio videos. https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ New 2014 Scion TC 4th Wall Build https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
Superjay Posted October 7, 2011 Report Posted October 7, 2011 just use a unibit to get through the metal. I'd use a T-nut to sink a thread into the false floor, use a pair of nuts (so they lock in place) to get the height right and a lock washer and lock nut (with the nylon ring) on the bottom. perfection done right Principal JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
AdamTheAudioMan Posted October 7, 2011 Report Posted October 7, 2011 Get some cobalt drill bits (kinda of heavy duty), and find some for the size hole you need, also for the bolts size. UNDER-CONSTRUCTION ''Old School Build'' maybe it sounds like an 18 cause theres 3 fucking "port" holes ghetto drilled in the "box" 190 db when your done? Yea that's the lowest decibal ill be satisfied with when I'm done like I said its stage one and I lost my job u guys should consider shit instead of just talk it lmao
tacomaguy1 Posted October 7, 2011 Report Posted October 7, 2011 be sure not to drill through the gas tank or anything else important Team Flex Issues
Cardboardcat15 Posted October 7, 2011 Author Report Posted October 7, 2011 Thanks for the quick replies guys! I'll probably end up doing what Jay suggested. It's awesome to be on a board like this Oh and don't worry tacoma, I've been paranoid about that ever since I started car audio! I've come to find my tank is under the rear seats My Channel on YouTube. Check it out for cinematic-style Car Audio videos. https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ New 2014 Scion TC 4th Wall Build https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
