Fi BTL N2 18" Box Help
Honestly, just ditch the 6x9's and give yourself some more room to work with.
You don't think I have enough space to work with? My car can't really handle more than 6-7 cubes after displacement without a suspension upgrade anyway. That's really the maximum.
How does the Fi Q 18" fully loaded handle a 6 cube box after displacement? I see it is like $150 cheaper and handles 1700-2000 RMS with cooling added. It's also more of an SQ sub for the lows and stuff so I'd like that... However it requires 6-10 cubes :(
Also, a Planet Audio AC4000.1D is rated at 2000 RMS but we all know that is BS... So would it be pushing 1500 RMS do you guys think?
Edited by jmander11
  • 4 weeks later...
Update: Just got my BRZ2400.1D in the mail, all that's left to do to hook it up is run the new 0/1 gauge wire...
It will be hooked up to my current PA 15" @ 2 ohms with an output of 1700 RMS.
With 2400 RMS at my disposal at 1 ohm i will pretty much have to go with the Fi BTl N2 18" Dual 2 ohm.
So... how does this sub perform in 4.5 to 5 cubes after displacement, does anyone know? I was also wondering what would be the optimal tuning frequency, 30-32 Hz?
usually less is more in cars. IMO, i think you'd be much better off with a couple of fi Q 12's sealed off from the trunk. even though you have slightly less cone area, sealed off from the trunk is usually louder. IIRC putting an 18 in a trunk with the back seats up is like putting a brick on your sub, which will make it heat up quick.
just my 2 cents worth. best not to "cram" an 18 in, especially in a trunk.
More box builds
I'm with captain stupid.
My seats do not fold down, however I leave the hatch (if you can call it that).. in the middle of the seats down... It is around 5 inches wide by a foot high so it should be enough. I only have this one amp to work with, and I can't afford another amp AND 2 subs.
Edited by jmander11
the q's would probably cost about the same as an 18 inch BTL :pardon:
and you could wire it to the amp at 1 ohm
More box builds
Yah I know how to wire it to 1 ohm :P. The Qs are 1500 RMS each, plus 200-500 RMS on top of that with cooling and I have only 2400 RMS to work with.
The 2 12" Qs are $814 shipped and the BTL 18" is $640 shipped, and both options require about the same size box?
Edited by jmander11
  • 8 years later...
11 hours ago, TjThaGreat90 said:
I have 2 18" Fi BTL neo looking to get a box made for Hummer H2
Specs per speaker
Overall diameter 18.5
Cut diameter 16.75
Mounting depth 11.25
Driver displac 0.26 cuft
Ported box 6-8 cuft
Anyone no someone that can build?
why the hell did you necro an eight year old thread?  go to sub/box and make a new topic
  • Who's Online   1 Member, 0 Anonymous, 1401 Guests (See full list)
