DC Sound Lab
Posted (edited)
They are 2 dual 1 subs. Both subs are wired in series parallel, one reads 2.0 like it should. The other reads 18.5-19.0 then when I hook them both together it reads 1.8-2.0... All the coils read 1.0 before I put it in on both subs. They are brand new, never seen power...
Edited by LoudNLow931
2008 Dodge Ram 2500 6.7l Cummins
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
Audio Technix Wiring & Sound Deadener
My Youtube
Feedback
meter each coil seperately don't forget to take out your lead resistance.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Just to double check im sure you are smart enough to notice this though, but are you reading it with the amps off? I tried to read mine once with absolutely no sound going through and i forgot my headunit was still on and my resistance was fluctuating quite a bit until i shut it off completely and it read like normal.
One thing you can try to do would be to measure each coil independent from each other to see if any coils have a problem, then hook each sub up in series but keep them seperate from eachother for the moment and see what they read. Each sub should read about 2 ohms when its wired in series and NOT connected to the other sub. If it does then repeat this to the other sub and see what it does. I had this problem before and i just brushed it off like its nothing and later in the day after i played them for a little it somehow fixed itself and my resistance was back to normal.
just want to see how they are wired with the dmm reading when they are wired. I have had a similar problem before and I just had a bad piece of wire.
I'm grabbing something to eat then when I get home ill test each coil separate. Yesterday they read fine so that's why I'm confused.
do you happen to have each coil on the sub wired to an independent bolt somewhere on the box? I did that with my sub and it is a hell of a lot easier to swap the sub from series to parallel without taking the sub out, plus i can troubleshoot it a lot easier too. If you have it set like this with each terminal of the sub going to its own bolt or wire on the box then just troubleshoot it from there.
OK I pulled it out and one coil read fine and the other one said 31.3. So I messed with the tensel leads and it dropped to 7.xx so I squeezed the tensel leads down on the terminal and it dropped to 1.1 then I let go and back up to 6.xx so I re soldered the tensels to the terminal and its sitting at 1.1 now. I think It might have been a bad solder connection?
4 FT1s
C1600.2
8 PWX 8s
ONX2.100
My Youtube
Feedback
sounds like it or maybe it cracked loose a little bit. It could have just cracked loose or may have had a cold solder connection.
