One last question, has to do with wiring.
Say i got a 1 channel amp, with 2 subs. How would i go about wiring that? Run the subs in series? (-,+,-,+) or (+,+ -,-)
What ohm subs? What subs? What amp? And whats the lowest impedence will the amp
will run at?
Edited by bassrace
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
Wow, wasnt aware all that effected it... Say with the AQ setup posted above cuz im pretty sure im going with that
Audiopipe subs are a no!
All the subs mentiOnes by my fellow SMD-ers are good and I wouldn't hesistate to try any of them!
But I'm going to add my list of subs too, im on my phone tho so no links, they arnt hard to find!
Skar vvx12
Sundown SA-12
Personal favorite (especially for low shake the hell out of everything, even the car next to you bass) the Obsidian audio OA12! Obsidiancaraudio.com
Study up and enjoy my friend! Oh and you don't have to worry about your window cracking.. Your rear view Mirror might not last long tho, and my dash cracked. But sounds great :shrug: lol
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
Get the 1 ohm subs and go with option 1 on this link http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=12#results
EDIT: Whoops those only come in dual 4 ohm duh.. Go here http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42 And do option 1
Edited by bassrace
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
As for box building its really easy . just get a design and cut sheet off of someone here and get homedepo to cut it for you then all you need it a screw gun / drill screws and glue . a few clamps wouldn't hurt either
REP
^^^^^^This then take it to an audio shop or woodworking shop to get your sub holes cut.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
And whats the benefit of building it myself over just buying one that fits right in my trunk. My trunk is small so most likely im going to be using as much space out of it as possible so the premade case basically does that for me
:noob: Im so confused on Ohms right now its rediculous.
*EDIT I think i got it lol.
Edited by mgbadboyz
premade boxes are almost never right for your subs . subs need to be in the right box although sealed boxs are way more forgiving but also way quieter
REP
  • Who's Online   0 Members, 0 Anonymous, 3078 Guests (See full list)
