Can anyone help me I've spent forever looking for specs on my 08' Orion D5000, I want to know the strapped power of these, I'm assuming 5000rms.? I also would like to know how to go about strapping it, I have done research with no luck. I'm trying to get another one and would like a little info on the subject if anyone can help. Thanks in advance.
Edited by bassrace
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
http://www.sonicelectronix.com/item_7562_Orion-HCCA-D5000.html i assume that'd be the right specs, so if you strap them it'd be 5000 together. Also if theyre strapable, itd have a master/slave input. Edited by cjN
2x sundown audio sa 12's
Crescendo BC2000
kinetik 1800, 1400.
Rockford punch 5,25 component set
MB QUART ONYX 4.80
Mechman 270a alt
Yes, but not for what I'm asking. I'm looking for the strapped specs and how to strap it.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
not to sure if you can strap that amp but i could be wrong
It has a master/slave switch so I'm assuming I can.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
Give Orion a call?
Geuss I'll do that tomorrow unless someone on here can help first.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
If it's anything like the new model you set the outputs to master on the main and put that to the output on the other(I believe if that's what the switch indicates, you may want verification), they should communicate that way. Set the other to slave and it will be set.
His:
Current model:
Edited by Maticus
