I will give this a try , thanks
No problem, let me know how it goes.
Also, here is a picture to help you out with it if you need.
Not my picture. Have seen it on here before, just found it with a quick google search.
thank you sir..will try it shortly
I tried grounding the RCAs, but still didn't work. Also I noticed if I unplug the RCAs from the amp the whine stops, however if I only unplug the RCAs from the deck the whine gets worse. Could my deck or amp possibly be messed up? Or is there anything else I could try?
There's so many variables that could be causing these problem.
I had this problem for awhile.
Headunit ground?
Change rca?
Battery grounds?
Speakers properly secured/ wires secured?
Power antenna ground?
Fuel pumps could cause this sound coming from the speaker...
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
Headunit ground?
Change rca?
Battery grounds?
Yeah it's just so frustrating. I don't believe it's the fuel pump, but I will go back and check these other things when I get home from work
Ground amp off of battery?
Check grounds to body?
Amp ground to body?
Corrosion on posts?
Power wires secured?
HMU!!!
95 Bonneville SSE
If the whine gets WORSE when you unplug the RCAs from the HU, then your HU is completely ruled out as a cause (or at least the only cause, lol, in my battles with alt whine I've always had to fix multiple causes, but take them one at a time). Try running a new pair of RCAs over your seats from HU to amp and perform the same experiments...
Edited by Merzbow
Amp ground to body?
Corrosion on posts?
All the wires are grounded to my battery under the hood. I ran my power and grounds from under the hood, so I have a good ground and the connections are secure
I will try this. Thanks
GROUND THE HEADUNIT!! and whatever amp you have. my HU is a B**** to ground. Its whines even after 2 GLIs and a added ground. you cant ground using factory ground. that is for a low powered factory head unit. More power = More Ground.
Pioneer AVH-p5700DVD | MB Quart Onyx ONX4.125 | 6.5 Alpine Type-S component & 6x9 3-way | Hifonics Brutus brz1700.1d | 2 - 12" Kicker L7 | Custom box tuned to 36 hz | 220A Mechman Alternator | 1/0 OFC Welding all the way back | Big 3 | 2 Farad Tsunami Cap | Deka 9a34 | 20% Tint | 6000K HIDs | Yellow Projector Fogs | Dual Out Magnaflow
  • Who's Online   1 Member, 0 Anonymous, 1628 Guests (See full list)
