Determining port area
herbykw
Read the vance dickason port method, and you will have a greatly tuned enclosure.
uve mentioned that twice yet wont state the method.
for those who dont know its from the loudspeaker design cookbook, and does not always work either
dv=diameter of vent
vd=sd*xmax <<<<<needs to be accurate
fb=tuning frequency
^^^what is the length supposed to be? Or do you just need to figure it out yourself after determining the port area that you "should" use?
your're suppose to figure out length after that.... this is not a method I use. i just noticed bcarter mentioned vance dickason 3 times without stating what the formula was/the issues with it
richard small (neville thiele+richard small = theile/small paramaters, or tsp's commonly) suggests a more conservative equation, but its similar
most people know this formula from carstereo.com, the minimum port area calculator. it is known to suggest WAAAAAYYYY too much port area in most cases. the answer is given in a diameter also, so the issue with that is a circle port of say 50sqin =/= 50sqin slot port. they will not act the same with identical volume and it doesn't account for flared circular ports
How does it work with multiple subs? If I did this correctly dv = 18,956.88. I am using 4 subs.
either your math is wrong or therein lies the problem. it will suggest diameters that are non-existent/not applicable in a car audio
Carstereo.com is not too big - that is what is required for a port that operates 100% correctly. The correct statement would be "most people use much less than what would be the perfect size, since it is hard to fit them into a small car box".
Notice those formulas do not say anything about box volume. Port area is not related to box volume. That was started as a very general guideline for people that do not want to take the time to determine what they actually need. . .
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
I used Autocad. I drew a 6" circle and then did did a properties of it and it gives me the area. and then I multiplied it by 2 for two ports and then divided it by your box volume. odd information about circles. whenever you double the size of a circle say 2" dia to a 4" dia you have 4 times the area.
So 1 - 4" circle is the same as 4 - 2" circles
Area of a 2" circle is 3.1416
Area of a 4" circle is 12.5664
The area of a circle is 3.14159 * radius^2
Note your example above, while (4) 2" tubes would have the same area as a single 4" tube, the port length would not be the same given the same net volume.
Current system:
Previous systems:
to operate 100% correctly at xmax.
most subs rarely see xmax through the variety of notes played so u can get away with less port area... dependent on power of course
Definitely depending on power. But I find car audio is where people try to run the most power and use the least amount of port area.
I see more subs damaged mechanically than thermally when used in cars. . .
I should add - many times the mechanical damage is from playing below tuning, but the point is still most car setups I see have no problem taking the sub to the mechanical limits, even above tuning.
Brian
Current system:
Previous systems:
Can you please correct me where I'm screwing up.
Start with SD 201.93 multiply it by xmax 16.5 which gives me VD of 3331.84.
3331.84 times 411.25 = 1,370,221.26. I then devide that by the square root of FB 35 which is 5.91.
1,370,221.26 devided by 5.91 = 231,847.508 to the 0.5 power = 481.5055 times 39.37
Total outcome 18,956.87..
I will be pushing these four DC lvl 2 8"s with a DC 2k.
06 300C 5.7 Hemi
K&N CAI
JVC KW-AVX640 6.1" DVD
DC Audio 3.5k
6 DC Audio 8"s
6 cubes 8" aero port at 32hrtz
http://www.stevemeadedesigns.com/board/topic/183798-chrysler-300c-8-build/?p=2731834#entry2731834
  • Who's Online   0 Members, 0 Anonymous, 2073 Guests (See full list)
