I am trying to test a headunit and am trying to hook it up direct to a battery. I am wiring the red and yellow to the positive and black to ground. This should work but it isnt. If someone has done this and knows what I am doing wrong please tell me. This headunit was working just fine when it was uninstalled. Am I missing something here?
the remote wire for the HU still needs power, generally the remote wire is the blue wire right?
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
Ground your antenna
Edited by Bigballa39213
98 Chevy Blazer 4 Door
Stock Everything
The New Setup
1 - Pioneer AVH-P5200DVD
1- Pioneer DEH-80PRS
2 - Blues Audio 5.25 Mids ( On the dash )
2 - Blues Audio BL8.0C Components ( In the front doors )
2 - Blues Audio BL8.0 Woofers ( In the rear doors )
1 - Linear Power 952 ( Dash )
1 - Linear Power 2202IQ Modified ( Components )
1 - Linear Power 3002 ( Rear Doors )
1 - SoundStream XBP-10 Processor
1 - SoundStream BX-20Z
2 - SoundStream DTR1.3400D
4 - RE Audio SX12D4
that should work.. thats how i ran a headunit once before
did you blow a fuse?
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
All that it should take is the power and ignition on 12v and then ground. Remote doesn't needa power. It should turn on like that
does the radio have a fuse on the back?
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
Remote I believe is used to power your amp when the h/u is on.
CJ:
thats the way I've tested h/u before and it worked, h/u fuse not burnt?
Is it a pioneer?
Stock Everything
The New Setup
4 - RE Audio SX12D4
CJ:
damn I look crazy
Edited by TRTC360
