sub direction in ext. cab
jballin2010
subs passenger side subs up..port driver side port up..doesnt doesnt sound like you left much room on the sides lol thats what id do if youre set on that
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
is that 13.5 external or after displacement.
mine was after displacemnt but the box was 55w 33t and 19d basically the biggest that will fit threw the door port was up and had 6" between top of box and roof
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
and you have it udner the window line?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
well mine is 56.5 wide 19 deep and 26 high
I rather have a smaller box that loads correctly rather than a big box that fires into some random area.
I ran a pair of 18's up with port up. Managed a 143-148 on ~1600w RMS in the 38-48hz area.
I hear subs forward and port up does better though.
Edit
here's a vid to show what it was like inside the cab. There's a bunch more on my youtube.
Hammerdown... 1%
Bolt the box to the back wall and it wont move.
Magic i know. ........
I love port sideways for lows
Hope you have a woofer that will agree with tuning way down there.
18" Q's are recomended at that frequency
I ran a pair of 18's up with port up. Managed a 143-148 on ~1600w RMS in the 38-48hz area. I dont think a single 6" will cut it..
well im going to do TWO 10'' (long) ports.. with 6" diameter a piece
