sub direction in ext. cab
jballin2010
Id leave 8" on 1 side and subs up port to pass side
3 8" ports tuned to 31hz
Should pretty much blow the pass side door off at 27-30hz
subs up or forward ?
2 12ks and i dont know what to do
build in the works!
"subs up port to pass side"
Hammerdown... 1%
so has someone literally tried both on 18"s?? "testing and trial/error" is not an option due to the height will be different then the depth so "flipping" it is impractical. . . looking for crazy lows, along with the strong punch
to be honest, what you will idealy want is a bandpass design, since a port in an ext cab truck doesnt really have anything to load off of.
Getting bass into the cabin of a W124 mercedes is impossible.
Current setup:
Temp 1999 panasonic HU
rockford 300.2 for fronts
rockford 200.2 for rears
rockford 400.1 for sub
Leaning towards a 8" in an exponential horn
DAMN YOU GERMANS AND YOUR 5" SPEAKERS!
My current box sure seems to load. Lol
....extended cab trucks should only us bandpasses? news to me ill keep that in mind when building in my single cab truck..damn there cant be anything for it to load off in there :good:
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
Depends, if you arent doing a wall, it will be loading off of the rear seat :3
Current setup:
Just side port all truck boxes.
Easy.
Easy.
thats the plan! i may make my sides higher since my box isnt built.. i just got all the wood cut. but i can get another sheet lol. im looking to stay somewhat practical ya know? (able to see out my back window, use top of box for storage, ect...)
