Ideas for LVL 6 12
OrionStang
I dont see sigs on mobile.
And got them turned off on desktop
Uhh.
I got a 10 coming in next week.
Ill take another look without cutting to much
I would appreciate any ideas, i'm taking it all in. Remember this sub has an 11-12" mounting depth.
SMD Super Seller
My Feedback Thread
Just did some test fitting with cardboard "enclosures". And yeah, 28x18x13 is it through the trunk. Tomorrow, i'm going to look at how much metal I am willing to cut to get a taller box in through the inside. An inch or two shouldn't be TOO bad, right?
SMD Super Seller
My Feedback Thread
Not bad at all
So with the carpet and trim out, I got 11.5" coming in through the car. I can easily trim another 3/4" of the metal 'lip', giving me 12.25". To go anymore, I would have to cut a thicker piece of metal that braces across the whole rear deck. Seems kind of structurally important.
SMD Super Seller
My Feedback Thread
plasma cutter and welder.
make your own rear deck. its a unibody. your back firewall will be fine.
just weld some braces to the corners :good:
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
Can you post a pic of the opening.
Too dark now, i'll get some shots up tomorrow though.
The cutting part is easy. But i'm no welder, and I don't think I know anyone local who is.
SMD Super Seller
My Feedback Thread
it slides in thru the front man..
box was like 32" deep
ill have to look for the exact size.. its saved somewhere
I had to do the exact same thing with my lancer. Take the folding seats out grind down the bolt that keeps the seat down and slide box in the trunk from the back seat. I have to take the back seats out everytime I wanna take the box out but now I know for a fact that I can fit a total box of 6.67ft3 in my trunk. I never would've thought it
2011 Mitsubishi Outlander
Sony 712
Soundqubed HDS208
Alpine MRV-M500
Transmission line enclosure
Soundqubed wiring
Knu rca
XS Power battery
CNF terminals
Pics of box design? Your just diong sub forward port forward right? Goin to be a tight fit. Can you rear mount the sub through the box from the trunk maybe
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 1083 Guests (See full list)
