Samsung 50" Plasma Tv Question
that means the cable going from the dvd to the tv is not passing signal , double check where you have the cords pluged in , you might have the plugs on the input of the dvd? or on the output of the tv?
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
usually this means you need to switch input sources. i have the same TV except a 56" and it says that on the screen when the source (I.E. dvd, blueray, cable, etc isn't turned on or needs to be switched on the remote to a diff. source)
I got banned for being an ignorant ass....and im a dickhole
i like men, michael jackson and large sausages
Another thing is, well yeah, a source issue, but if the dvd is HD upconversion, you need to select the dvd on the same output, as the tvs input - Basically 720p out from DVD, and select 720p input on tv
My tv did the same sht for about an hour until I got in to the menu of the DVD player
that is typical of wide screen tv's and its the program. You can go and change the apect/picture size with your remote to make it fit better but sometimes you loose a little quality (due to "streatching" the picture) or a small part of the picture around the edges from blowing it up bigger.
Scientia est Vox
SMD SUPER BUYER/SELLER
how do you like the picture on this? I have a chance to pick up the 42" for real cheap. I have not had a chance to go look at them yet though.
2005 Nissan Altima 2.5 S
HU: AVIC-D2
Fronts: ARC Audio KAR KS6006 Components
AA Poly Mids/ CDT CW-19 Tweets in kicks
Front Amp: Profile AP400x2
Rear Fill: None
Sub: DC LVL 4 (CF Dustcap) x2 (waiting for dustcaps)
AMP: RF t10001bd x2 (1400-1500 @ 1 ohm)
Wire: Welding Supply/Lighting Audio 1/0 Power/Ground
Zero Noise 2.0zn RCA (x2)
260 Amp Iraggi Alternator
  • Who's Online   1 Member, 0 Anonymous, 1435 Guests (See full list)
