DC Sound Lab
you got the ar cone??? Cj told me they do not make them for 15's
Im pretty damn sure....
call rusty it might be just the reinforced surround... I don't think so cuz I asked for reinforced cones too... I with they made carbonfiber cones
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
The ar cone upgrade isn't offered in the 15'' version... I'm kinda mad about that right now lol. I'll be getting my 15'' reconed with the upgraded spider pack but im wanting to do that ar cone as well.. being that im running about 3k-3.5k daily on mine :D You'll be totally fine with that battery bank and power on those subs if you dont clip the shit outta them.
I think u are misinformed i just ordered a 15 " recone.....with a reinforced cone wide surround
That the 1 reason on why i stopped goin with dealer here on the forums it they forget stuff or dont mention things when taking orders like i never knew about different packages towards spiders and ect.... from now on im calling dc audio direct
Id do d2s or 1.4s.. your rise should help you. The ar cone has wider surrond and is stronger. You can also do carbon fiber cap to add strength to the cone on that power..
He already has the carbon fiber caps on them. <_<
Correct, its ethier that or do 3 18' xl woofers in the mustang i just dont think i will have enough room in there i did rough measurments and i only see like 14cuft max while still staying behind the bpillar but i didnt remove no trim peices and i have some backseats in there..... but in all honestly will there much of a gain from slight increase in cone area? im its still the same motor and ect...
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
yupp thats what my smd-dd1 is for plus :drink40: is for
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
good shit then bro and yea ill call rusty then :D thanks for the tip
1 Crossfire XS v2 15"
2 Deka group31a's
1 XS Power D3400 (under hood)
1 Addictive Audio 500.1 :D
1 Rockford 3sixty.2
4 Crescendo pwx 6.5s
2 Pyle Pro Super tweets
1 Crescendo 1000c4
Kenwood excelon x494 Head unit
Big Three upgrade
All 0 gauge of course
1 4.56c^ft box @28hz
(New Best official db score= 151.2 @ 36hz)
i have a powerbass 4k xta on a 12in xl with level 5 spider and it does just fine so i think you should be fine with that power on 3 15s expecially if your doing a wall and can do lots of port area . and by the way i have 3 powerbass 4ks and three 12s" xls , my coil is D2 so each amp is at 1 ohm before rise
2 12ks and i dont know what to do
build in the works!
Realistically 2500 rms clamped per XL with stock spider setup IMO daily.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
i do plan on doing upgraded spiders probley the same combo on what ray was saying earlier, but idk when i call rusty i will talk to him more and here what he has to chime in now im debating on 3 18 or 15 i can get the 3 18 baskets stupid cheap right now so im wondering if able to pull off 3 18 walled in the mustang how much space you think will good for 3 18 walled?
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
With a stiff spider setup ( I had 4 medium 2 stiff ) we had no failures on 4500 rms each daily before rise. You'll want 15 - 18 cubes net
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
Look at the dc integra or poorboys build on here 2 xl 15s on a 9k..... both have tried 3 subs in a will and both had better luck wit 2 subs
Ur jammed for airspace, I would recone to 18s and just do 2.... and be easy on the power goin to em.....
or u could try 3 15s, I think ud be better off with 2 subs
Just my opinon
And get lvl 5s :peepwall:
If u don't mind the 40+ lbs lol
SCSB
Build logs:
