i would assume that since he has so many of them in series that no resistors would be needed for a 12 volt setup
thats what Im thinking too, but even the pre-made led lights you buy for dome lights have resistors and what not.
and my LED blinkers are resistor central!
Maybe a link to the seller you bought them from, or more info on the leds?
Well the are rated at 3.2-3.4v. In the first pic you can see me wiring them together in groups of 4 leds in series. That way each gets 3v if source is 12. Then i wire groups of them together in parallel so each leg of 4 gets 12v.
No resistors, but like i said, there's 104 in my dome, so the total is always going to be divisible by 4 =P
i resolve to be a nicer moderator.
Tercel build R.I.P.
Eclipse build Old New
V-Dub
My feedback.
I would highly recommend running resistors, and 12v Vregs with your LED's. A car power supply is very volatile, and it will kill led's, especially the cheap ones. I use 7812-style vregs, they each handle 1 amp of current and put out 12v steady. I buy them in packs of 5 from my local electronics supply store for $3.
Too many projects, too little time...
"vregs" haha when nerds have swag. :P
Yeah i prolly should, but its whatever. They work now and they are only on when the door is open, so i'm not stressin.
bahaha!
I did an LED dome light like 3 years ago and had that problem, hence my warning to you. After about 3 weeks I was dropping LED's like flies. Same with some Oznium strips I used for puddle lights. Using quality LED's also helps: I am working on a taillight retrofit using Philips LumiLED's, underdriven, and they are bright as heck (I made a test board with twelve of them and it's bright enough for a third brake light) I figure going a little conservative on the power and overkill on the LED count will make for a bulletproof setup (they are 70ma LED's and I'm driving them at 50)
