When do I know when I should get a second battery?
hello, I have a question, as I am still newer to car audio.
I want to know when I should get a second battery or a cap, at what watts. I have a 600 watt system right now, but at christmas time i want to upgrade the amp and subwoofers to about 1200 watts RMS. Will a need a capacitor or a second battery for this new setup? my battery right now shows no signs of having trouble taking the 600 watts RMS at all. Thank you for your help!
I wouldn't get a second battery, do the ''Big 3'', more current flow.
UNDER-CONSTRUCTION
''Old School Build''
maybe it sounds like an 18 cause theres 3 fucking "port" holes ghetto drilled in the "box"
190 db when your done?
Yea that's the lowest decibal ill be satisfied with when I'm done like I said its stage one and I lost my job u guys should consider shit instead of just talk it
lmao
You need to figure the current draw of your setup and then plan accordingly. Your stock equipment may or may not suffice, but that also depends on your stock equipment. What size alternator? What kind of wiring? And you're going to want a deep cycle battery eventually. Make sure the reserve and amperage can properly sustain voltage at acceptable levels.
what vehicle and engine? for instance my jetta will probly run 700 b4 it needs a new batt while my f150 ran almost 2k rms no prob stock
BUILD LINK: http://www.stevemeadedesigns.com/board/topic/112034-2-sundown-18s-98-f-150/page__p__1565972__fromsearch__1#entry1565972
98 Ford F-150
Truck:
37" superswamper tsl radials
16" ion alloy wheels
3" body lift
2" suspension lift
Offbrand brushguard
PIAA driving lights
6000K HID's
System:
2 18" Sundown Nightshaed
Aq3500
Custom Fiberglass box
fosgate T1 6x8 Coxials
bass inferno 2000 watt 4 channel
2 XS power d3100's
0 Gauge
for 1200 watts rms thats going to be around a 100 amp draw.. i would do the BIG 3 upgrade..and at least get something like a kinetik hc600 or shuriken bt20 xs power d680 etc.. just so it has a little more reserve power rather than the immediate demand from the under hood battery..
capacitors dont help with anything at all..well maybe a digital volt meter but thats it... they r totallyt worthless... unless u are using like 400 watts or so and have a 1 or 2 farad cap...then yes it would help some to maintain voltage..but not much
^this
98 Ford F-150
Truck:
3" body lift
2" suspension lift
Offbrand brushguard
PIAA driving lights
6000K HID's
System:
Aq3500
2 XS power d3100's
0 Gauge
anything over a thousand watts would get an upgraded battery like a d3400, when you go to 2000 watts i would add another battery just to have a bit more reserve, assuming you have an alternator to support those batteries
  • Who's Online   0 Members, 0 Anonymous, 578 Guests (See full list)
