what would i need electrical wise for 2k? no idea how much good batts cost but id like to keep it as cheap as possible. it will be for daily. my car is a 2001 ford taurus, if someone could find what kind of alt it has that would be great i cant find it anywere. :drink40:
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
What amp? I know you said 2k ,but what kind?I would upgrade your factory battery and put the biggest xs battery in its place and then do the big 3.Then go from there.
Member of Team 808
Member of Team North East Spl
most likely a crescendo 2k
also if im gonna run 2 batts could i just keep my one i have up front then just run 2 batts in the back? the batt i have up front is some everstart idk model or anything
Edited by new guy
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
run one in the front and one in the back. Best is to get 2 good audio bats at the same time. If you can't swing that, replace the one up front first, then add a second in the back.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
I would replace the front one with a xs and then add 1 to the rear of the car. Reg batteries are not the same as ones made for car audio.So keeping the factory bat will be a waste.
Member of Team 808
Big 3 and a run of 0 With one 2100 in rear and strong stock batt you should be fine
i would ditch the factory battery.The whole idea is to get more juice to the amp/amps, so why would you use a factory battery that wont perform up to your needs.
Member of Team 808
alright thanks im probably gonna be getting a kinetik 1800 for really cheap, what would be another good bat to run with this one?
Edited by new guy
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
If you wanna stay with kinetic, they make a 2400.you wont need any more than that. And i would run a pos. and a neg 0 ga wire from the front battery to the rear.
Member of Team 808
  • Who's Online   0 Members, 0 Anonymous, 2595 Guests (See full list)
