You cant clear the code its not a check engine light its gonna be on pull the bulb. :) or get oem pads and go from there. did you check rock auto for the oem pads?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
O'riellys has code scanners that they sell for abs etc if there is 1 near you go in and talk nice and see if they will scan the code fore you...i have the same inovia scanners at my shop i bought from them ...most of the time they have a demo model they will let customers play with ....it should tell u witch sensor it is...write it down and Google it or look in a book on your car ...they may have 1 there if you dont (witch you should have anyway before you try to fix something you dont fully understand) or you can go to all-data and pay the $25.00 for your car and get all the info the dealers do.... good luck
or just buy the right pad....lol
Edited by extremeauto
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
I agree with what N8 says. I have never worked with the vw's using the sensor I have worked on plenty of the mercedes that use a similar set up to what you describe. The answer for them is use an oem approved replacement. On those it is limited pretty much to either mercedes original or wagner thermo quiets and not a whole lot of difference in price. So I would put in an approved pad and take back the ones without the sensor.
Edited by photochrisb931
Barstad
you could just get some cheapo pads and get the sensors out. I've done this before for a customer who wanted to keep the high performance pads. Just tapped them up, zip tie, all black, could never see them.
  • Who's Online   0 Members, 0 Anonymous, 878 Guests (See full list)
