ok so i have a audioque hdc3 18 inch sub its brand new i made a box wired it up and a friend gave me a amp to use thats also brand new and i cant figure out why this wont work...i wired my amp up and hooked the speaker wires to the amp. the amp is putting out power through the speaker wires but the sub isnt playing anything. its confusing the hell outta me ive never came across this problem. any ideas? oh and if you take a 9 volt battery and touch the speaker wires to it the sub moves so i dont understand it, any help is appretiated thanks again guys
how do you know the speaker wires are getting power? can you see the electricity flow through them? /sarcasm
need more info. what kind of amp. what coils on the sub. how do you have the sub wired to the amp
edit: does the amp even turn on?
Edited by Kranny
Check your ground, or move your ground wire to another part of the chassis.
I had this same problem, and I relocated my ground wire to another spot, it worked!
UNDER-CONSTRUCTION
''Old School Build''
maybe it sounds like an 18 cause theres 3 fucking "port" holes ghetto drilled in the "box"
190 db when your done?
Yea that's the lowest decibal ill be satisfied with when I'm done like I said its stage one and I lost my job u guys should consider shit instead of just talk it
lmao
well the amp turns on powers up fine. upon searching some more i realized my second batt was only putting 3 volts to the amp...so im charging that as we speak...i used it to start my truck one day and forgot to recharge it oops. i have a fosgate amp in there before and one day it quit working and went into protect mode and now that amp will turn on but wont put nuttin out so my friend gave me a autotek pos 2000 watt amp to use for now the amp and sub are brand new, the sub i know has power going to it cuz i probed the speaker wires with a dmm at the sub... im hoping maybe the low voltage on the second batt is the problem. but wouldnt it still put at least something out with only 3 volts? my rcas are good i checked them as well.
edit: sub is wired down to 1 ohm its a dvc 2 ohm. and yes amp is one ohm stable incase your wondering
Edited by 96saturnsl
Its most likely the voltage. Im pretty sure there has to be a certain amount of voltage to the amp for it to operate.
subwoofers - two eclipse 88120s
box - 3.4 cubes tuned to 32 hz
amps - aq1200 and pheonix gold zx450
New build :
2 obsidian audio 15s
same amp
6.1 cubic foot box tuned to 32 hz in a civic hatch
If the battery only has 3 volts I'm going to say that it is a dead battery.
formerly known as Blue86f150
its a 4th order just because its tuned in the 40z doesnt mean it wont reach down and jiggle your balls at sub 30 hz frequencies.
Regardless if they were dipped platinum and were stuffed in Beyonce's twat.....way too fucking exspensive
this sux camel dicks
considering anything under 9 is a deep cycle Id hope his second battery is a D cell.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1585 Guests (See full list)
