DC Audio, Sundown, XS Power and Zed Audio
All in superb shape never abused and in working condition. Prices OBO and shipped. if you low ball you will be ignored.
Zed Audio Deuce $300 $275 Shipped
Zed Audio Miniliths $175 Ea $125 Ea plus shipping
Sundown Audio SAZ3000D $600 $575 Shipped Sold!
DC Audio 12" Level 4 w/ level 5 parts Dual 1 ohms $500 For the pair. $475 Shipped Sold!
Offer and Trades with cash will be considered. (Double Din)
I will package for more savings as well.
I have 3 D1200 XS power batteries that may be up for sale as well but I will see how these go first.
Just to be clear these are used so they are not 10 out of 10 I rate conservatively so I would say 8-9 out of 10 on all of them. I can get more pics if you want.
Thank you for looking.
what LVL 5 parts are on the 4's? How long did you have them hooked up?
03 Wrangler Sahara
6" lift (5 inch suspension 1 inch body)
20" Boss Rims with 33" tires
Front and back bumper guards
4 3/4 ton winch
Kenne Bell supercharger with cold air
Full Exhaust
Pioneer mvh-p8200bt
Pioneer Components
COMING SOON...
3 12" Kicker CVT's
RF T1000.1BD
They were hooked up for about a year and a half. I am old so they rarely were cranked up and they were NEVER abused. I still have my first pair of 12" DC level 3's still that I got when rusty first started out. I Am into SQ not spl. Skittles on here has seen my system and heard the set up. Others here who live around and here know me know I did not use them too much either. If you have any other questions feel free to ask... Thanks
Im looking for xspower batts.. if you do sale i would be interested.. glws.
2008 TBSS Black Granite
Alpine CDA-117
Clarion EQS746
AudioQue Supertweets @ dash
Alpine DDT-s30 @ b pillars
Alpine SPR-60c @ front doors
Alpine SPR-60 @ rear doors
Alpine PDX-f4
Second Skin DampPro
KNUkonceptz Wiring
DCpower 270amp alt
Optima YT underhood *temp
Two15DCxls
Hifonics bxi2610 *temp
saz4500 and 4 xp3000s coming soon.
Miniliths
Specifications
  • Output Voltage (volts into 1 ohm) 24.5
  • Output Voltage (volts into 2 ohm) 28.3
  • Output Voltage (volts into 4 ohms) 28.3
  • Output Current (amps into 1 ohm) 24.5
  • Output Current (amps into 2 ohm) 14.15
  • Output Current (amps into 4 ohms) 7.075
  • Continuous Output Power into 1 ohm 600wx1
  • Continuous Output Power into 2 ohm 400wx1
  • Continuous Output Power into 4 ohm 200wx1
  • Typical Continuous Output power into1 ohm 650wx1
  • Typical Continuous Output Power into 2 ohm 480wx1
  • Typical Continuous Output Power into 4 ohm 260wx1
  • Continuous Output Power 2 channels bridged into 2 ohm 1,200w x 1 *
  • Continuous Output Power 2 channels bridged into 4 ohm 800w x 1 *
  • Continuous Output Power 2 channels bridged into 8 ohm 400w x 1 *
  • * With TWO Miniliths bridged
  • Minimum Speaker Impedance 1 ohm
  • Minimum Speaker Impedance in Bridge Mode 2 ohm
  • Frequency Response at 1 watt into 4 ohms/channel 11-150Hz -3dB
  • Frequency Response at rated power into 4 ohms/channel 11-150Hz-3dB
  • Input Voltage range for rated power into 4 ohms 0.22-7.4 volt
  • Input Impedance (10K ohm on "mono-bridge" input) 39K ohm
  • Noise below rated output (30KHz limited) -89dB
  • Channel separation at 2KHz Infinite
  • Damping Factor at 20Hz with 4 ohms >100
  • Total Harmonic Distortion with 4 ohm 20Hz-150Hz
  • From 1 watt to 2dB below rated power <0.5% **
  • ** Frequency range 20-150Hz only
  • Low Pass Crossover (24dB/octave) 40-235Hz
  • High Pass Crossover (24dB/octave) 11-48Hz
  • Equalization Parametric 26-160Hz
  • Remote Level Port with control Yes
  • Line Output Yes
  • Protection - Short Circuit, DC, Thermal Yes
  • Power Source ----10-14.5v DC Negative Ground ----
  • Current Consumption with Sinewave at 4 ohms 20A
  • Current Consumption with Music at 4 ohms 6A
  • Idling Current <3A
  • Size W x H (302.22mmx74mm/11.9"x2.91") x L 314.4mm/12.4"
  • Shipping Weight (Kg/Lbs) 7.3/16
Deuce
Specifications
  • Output Voltage (volts into 2 ohm) per channel 28.28v
  • Output Voltage (volts into 4 ohms) per channel 28.28v
  • Output Current (amps into 2 ohm) per channel 14.14A
  • Output Current (amps into 4 ohms) per channel 7.07A
  • Continuous Output Power into 2 ohm per channel 400wx2
  • Continuous Output Power into 4 ohm per channel 200wx2
  • Typical Output Power into 4 ohm per channel (0.8% THD) 245wx2
  • Continuous Output Power 2 channels bridged into 4 ohm 800wx1
  • Continuous Output Power 2 channels bridged into 8 ohm 400wx1
  • Minimum Speaker Impedance per channel 2 ohm
  • Minimum Speaker Impedance in Bridge Mode 4 ohm
  • Power Response at any power into 4 ohms/channel 10-100KHz -3dB
  • Frequency Response at rated power into 4 ohms/channel 10Hz-25KHz -0.1dB
  • Input Voltage range for rated power into 4 ohms 0.26-8 volt
  • Input Impedance 47K ohm
  • Noise below rated output (30KHz limited) -101dB
  • Channel separation at 2KHz >80dB
  • Damping Factor at 20Hz with 4 ohms >200
  • Total Harmonic Distortion with 4 ohm 20Hz-20KHz
  • From 1 watt to rated power. Typically less than 0.05% <0.08%
  • Intermodulation Distortion <0.08%
  • Phase response at 20KHz Lagging 10 deg
  • Slew rate (volts per micro second)-In"Flat" mode 15
  • Low Pass Crossover (all are 24dB/octave) 46Hz-3.5KHz
  • High Pass Crossover (all are 24dB/octave) 46Hz-3.5KHz
  • Equalization (Zero to +18dB variable control) Bass Boost @44Hz
  • Remote Level Port with control N/A
  • Line Output Yes
  • Power Source 10-14.5v DC
  • Current Consumption with Sinewave at 4 ohms 54A
  • Current Consumption with Music at 4 ohms 17A
  • Idling Current <2A
  • Fuse rating with 4 ohm load/channel 60A
  • Fuse rating with 2 ohm load/channel **** 80A
  • Size W x H (302.22mmx74mm/11.9"x2.91") x L 444.4mm/17.48"
  • Shipping Weight (Kg/Lbs) 11.8/26
All specs taken from Zedaudiocorp.com website
  • Who's Online   0 Members, 1 Anonymous, 1368 Guests (See full list)
