I have my remote wire for my amps running through a kill switch on the dash. I hit it the other day when I saw a cop, and when I turned it back on, my mids and highs amp wouldn't turn on. Pulled the fuses, put them back, now power on/no output. Sub amp worked fine the whole time. Is the kill switch what caused the failure?
Mids/highs amp is a Cadence F600-4, sub amp is a Massive N3.
I tried swapping RCAs around to no avail.
Ugh.
Too many projects, too little time...
Make sure the wires are still in contact with the switch
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
I have that on my amps been doing it for year no problem
Check ur switch
stevemeadedesigns.com/board/topic/105505-silvia-first-time-build-kenwood/
Can you hook an iPod directly to the amp to test it? Did you mess with any HU settings?
I'm in Beach Park, so not far from you if you can't figure it out and want to stop by I could help you troubleshoot it
Check the input side first. First, make sure your speakers are still good and in working order. Then, get an ipod (or anything with a headphone jack) and plug that into the RCA inputs of your amp. If your amp works then it is no longer getting a signal. If it doesn't work, probably something wrong on the inside of you amp.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
I swapped the 4-channel's RCA's to the sub amp and was able to get output to the subs so there's still signal going through. I think my amp crapped out.
I'm going to try swapping another amp in to see if that one works.
  • Who's Online   0 Members, 0 Anonymous, 550 Guests (See full list)
