justin_garrett Posted November 13, 2011 Report Posted November 13, 2011 OK just a plain and simple wire question here. I have about a good 50ft of wire laying around that is used to go from a power pole to your house for the meter box on your house what im wanting to know is if it would be ok to use on a car for the big 3 and running to your amps. or would it just be better to get some 1/0 wire 1998 neon R.I.P 137.5 db's Youtube videos http://www.youtube.c...tingarrett64067 2000 Eclipse Headunit = pioneer avh-p1400dvd Subwoofers = 2 DC audio lvl 2 12's Amp= Vibe bass 5 1500rms @ 2ohms Single run of 0awg power and ground wire ( Big 3 wire upgrade comeing soon )
Tarball Posted November 14, 2011 Report Posted November 14, 2011 OK just a plain and simple wire question here. I have about a good 50ft of wire laying around that is used to go from a power pole to your house for the meter box on your house what im wanting to know is if it would be ok to use on a car for the big 3 and running to your amps. or would it just be better to get some 1/0 wire What hardware will you be running ?? In general though, get some decent 1/0, higher strand count is better. That "power pole" wire is good for powering your home but for car audio the high strand 1/0 has more surface area (increased current potential) and you can find some very flexable stuff to make wire nvigation in your car simpler. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
pwdrblucivic Posted November 14, 2011 Report Posted November 14, 2011 I second that!!!! House wire is for houses.. You need to use good quality car audio wire with high strand count.
justin_garrett Posted November 14, 2011 Author Report Posted November 14, 2011 i figured it would just be better to get some 1/0 wire but figured it wouldn't hurt to ask and as for what hardware i will be running its 2 vibe space 12's dual 2ohms powered by a vibe black box bass box 5 that is rated at 1500rms at 2ohms 1998 neon R.I.P 137.5 db's Youtube videos http://www.youtube.c...tingarrett64067 2000 Eclipse Headunit = pioneer avh-p1400dvd Subwoofers = 2 DC audio lvl 2 12's Amp= Vibe bass 5 1500rms @ 2ohms Single run of 0awg power and ground wire ( Big 3 wire upgrade comeing soon )
Team808 Posted November 14, 2011 Report Posted November 14, 2011 ya just stick with the car audio power wire. Member of Team 808 Member of Team North East Spl
