Impedance rise Question
  • 1 month later...
I commend you on searching for a subject and finding the answer :good:
What dc hoe said.
1 big amp, or 2 little amps (strapped or ran independently).
Either way the same woofers in the same box, in the same vehicle will have the same impedance rise, even if you wire it to .25ohms, your actually rise will be the same, but just different numbers.
So if you wire 2 dual 1ohm woofers and wire them to 1 ohm, and rise to 4 ohm
or
if you take your 2 dual 1 ohm woofers and wire them to .25 ohms and rise to 3.25 ohms.
Your actual impedance rise is still going to be 3 ohms.
kinda late, and tired so hopefully I worded this to make sense. lmao
Not to thread jack but...
I always thought rise was a ratio. Like wired to 2 ohms might yield a rise to 6 ohms at X frequency, but the same thing wired to 1 ohm would rise to 3 ohms at the same frequency :trippy:
Edit
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
  • Who's Online   0 Members, 0 Anonymous, 771 Guests (See full list)
