new box for 2 15 l7
elastic
Why tune so high? Are you going strictly for numbers? Cause at 40hz tuning you will lose a lot of the lows, which may affect the sound of your music depending on what you listen too. You can forget all about any C & S, but the rock w still sound okay. My factory Kicker enclosure was tuned @40hz w an areo-port, and I didn't really care too much for the sound of it. But it did get loud on the higher tones...
IMHO if you just want to get better numbers AND still sound good, I'd try the 35hz tuning, with the proper dimensions. I'll see what I can whip up for ya with Torres, just so you will have something else to think about. The subs up port up is a good idea
EDIT
So how about this?
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
This is an enclosure that I built for my Ford Explorer:
... (2) 15" Kicker L5s - Amp: SoundStorm EVO5000
I'm metering 148.1db on music - SB1
Vehicle: 1999 Nissan Sentra GXE 4-Dr
Head Unit: Alpine CDA-9852
Front Stage: Kicker DS6.5s w/ (4) Power Acoustik NB.4s - Rear Stage: (4) JVC 5-Way 6x9s
Sub Stage: (2) 12" Lanzar OptiDrive 1232s - Custom Ported Enclosure: 6.81cuft Tuned @ 32Hz
Sub Amp: (1) Kicker KX2500.1D - Highs Amp: AutoTek AT-1200.4
Processors: Clarion EQ-746 & Clarion MCD-360
Wiring: Install Bay 1/0 Gauge ( Including Big 3 Upgrade )
Batteries: (3) EverStart Maxx's ( 750 CCA ) 1 In Front & 2 In Back
DJ's Audio Installation
Other words... Change your enclosure...
hmm well whats your voltage at do you have a voltmeter?
What oahm you running the subs @
id try to wall those babies if your going to change the box ,but to sacrifce your rear window.
the big 3 if you have not
try changing the box position /give the port more room
inverting the subs might gain u db's (may require box modifications )
after all the changes whos to say that you may not want to go louder . you could sell you setup or add to it
2 more subs=still a chance to add another amp if your electrical system is up to it .
SuperBass
check out⊂ http://www.youtube.com/Bassknots
129.3 meca 136.8 db drag (60 hz peak)
http://bassknotsstereo.blogspot.com/
comment/subscribe and stay tuned ,working on 150 db http://www.stevemead...r/page__st__380
  • 3 weeks later...
hi
i finally have time to build a new enclosure :)
subs up, port up. the enclosure will have same outer dimensions as the old one.
so what do you think about this?
probably i dont need extra internal bracing as the port is pretty deep and ill be doing double layer of mdf on the sub side.
will look like that:
P.S. Torres calculator says a 36 hz tuning when i want to make the port 32" deep. its a bug? i cant tune lower than 33 hz.
my 15 L7 build
my youtube channel with lots of L7 videos
  • 1 year later...
I would like to build a enclosure in a ford explorer also, May I ask the length of your box?
I am going to build a rectangular box, with 2 15s, aero port tuned to 32-34hz. (7 cubes after displacement)
Sa15s if you were wondering. Anyway, How long is your box? or how long of a box can I slide in?
  • Who's Online   0 Members, 0 Anonymous, 1056 Guests (See full list)
