How Will This Sound?
Hi guys, how will this sound, will it be ok? 4x RE SE 15" in 8 or 10 ft^3 total tuned at 34-35Hz? thus giving each like 2 or 2.5 ft^3, I know RE recommend 3ft^3 Compact and 4ft^3 optimal, but could they work in smaller ported enclosures?
Also wich one of these two you guys will choose: 4x RE SE 12" in 7.2ft^3 Ported tuned at 34Hz or 4x RE SE 15" in 7.2ft^3 Sealed.
Anyways thanks i need some opinion/advice before i make decisions
Shaking The Neighborhood.
if the lowest RE recommends is 3 cubes for a 15...i'd try not to go smaller than that. the enclosure can make or break your setup
EDIT: damn typos :mad: :mad:
Yea definatly!!the box can definatly make or break a setup so yea i wouldnt go ne smaller than the recommended..and i would go with a ported box!!i used to have 2 12" RF P2s in a small seald box and it sounded ok but then i cut 3-1/2in holes and stuck 2 3-1/2in aero port tubes in it and you wouldnt believe the diff. and then i went to a 6cu.ft. box at 32hz(my current box) and now i have the 2 12" TC-1000s in and i am rite round the low to mid 140dbs ;) ..so deff ported!
Vehicle-2014 Ford Fusion on 20" cruiser alloy obsessions
Subs-4 8" sundown audio E8v3
Sub Amp-Hifonics Brutus Elite 1200.1
box-2.8cubes after all dis tuned to 32hz 4" aero
Mids and highs-2 sets of Memphis PR 6.5 components
Mids amp-Hifonics Brutus Elite 800.4
Deck-Factory Integration
Wiring-Memphis
40sqft of damplifier Pro
http://www.youtube.c...14?feature=mhee
SMD SUPER BUYER/SELLER
go for the 4-12ers that will be louder yeah, you can also do more with your enclosure, is not good if RE recommend 3 cu/ft a 15er to go under the 3 cu/ft just go for the 4-12ers that will be good choice, AND LOUD
Alpine HU 9855R IPODRE XXX compo, 2nd one is comingrockford t8004 amp ( 4 channel ) rockford (4x) T30001bd mono amps @ 0,5 ohm for dailyRE Audio 18'' MT (2 x) Enclosure is 400 LITER tuned on 28HZ28HZ - 150db TL 200731HZ - 152db TL 2007Max Score 157,4db TL 2008 @35hz----------------------------------------------NEW INSTAL UNDERCONSTRUCTION!!ALPINE HU 9855RIPOD4 RE XXX COMPONENT SETS4 RE COAXIAL SETS4 FI BTLS 18'' SUBS8 RF T4000BD'S MONO AMPS4 RF T8004 4 CHANNEL AMPS16 northstar nsb 125 batts70mm wiring10 RF 100 farad powercaps
  • Who's Online   2 Members, 0 Anonymous, 973 Guests (See full list)
