OK so im planning on putting a saz1200 on two sa 8's, if there is no devider in the box, how do i wire the subs to a 1ohm if its a mono amp but has 2 speaker outputs?
PLEASE HELP!
Thanks,
Colby
2001 Dodge Ram
Kenwood Deck
Pioneer speakers
Is the box ported or sealed? If sealed I think there should be a divider. And if there dual 4s you do one set going to the speaker and do positive to positive negative to negative and jump the positive to the other positive and negative to the other negative. And repeat for the 2nd sub.
subwoofers - two eclipse 88120s
box - 3.4 cubes tuned to 32 hz
amps - aq1200 and pheonix gold zx450
New build :
2 obsidian audio 15s
same amp
6.1 cubic foot box tuned to 32 hz in a civic hatch
its not nearly as hard as you are making it.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
google is your friend. 8bazillion results when searching for how to wire a ________ woofer...
1999 Lincoln Town Car-(build underway)
- (2) SA15s, 4th order, DAT 2500.1, O2 mids n highs, 250a alt, HC 2400, Big 3....
1994 Pontiac T/A for speeding tickets.-
- Currently on jack stands, wanting to be a real race car
"Your local forecast, all the ladies in the metro area should expect to see 8 inches tonight" - The Todd
Decaf, on 01 November 2011 - 02:38 PM, said:
i provide the ammo for destruction, the trigger finger is connected to the volume knob tho
URBAN GORILLA AUDIO
PLEASE HELP!
Thanks,
Colby
Okay, to start with, it's a mono amp, therefor you would want a single chamber, single port.
And the two speaker outputs are so you can run more than one positive and negative, if you need to.
They don't all have to be used. The 2 positives are the same, and the negatives are the same.
To get the wiring your looking for, wire the positives together on each sub, then the negatives on each sub.
Then your positive from the amp goes to one of the positives on each sub, and the same with the negative.
Negative from the amp to one of the negatives on each sub.
And then you should be wired to 1 ohm. Hope this helps.
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
What ohm subs?
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
Posted (edited)
thanks guys see i though i could wire it like that, sorry im such a :noob: so you guys think this setup sounds good though and i was gonna do dual 4s to get 1 ohm right? and thanks guys for helping me continue to learn haha
Edited by Reg_Cab_Slammer
2001 Dodge Ram
Kenwood Deck
Pioneer speakers
PLEASE HELP!
Thanks,
Colby
kenwood excelon -- head unit
kicker amps--
1x 1000.1
1x 750.1
kicker subs--
2x shallow mount subs
2x cvr 12's
factory mids and highs
(a major upgrade would be nice but,
limited space and funds)
