I got a sweet deal on some Eclipse SC8365 3-ways & I'm wanting to run them active but not sure on what amp, crossover, etc. to use & wanted to figure out everybody's opinions first.
I was thinking of using this amp - http://www.sonicelectronix.com/item_37765_U.S.-Amps-XA-800.4.html
Running the woofers in parallel for 2 ohms but not sure what crossover to use & running the mid & tweets through the factory crossovers in the normal 4 ohms.
And for some references here's the factories crossovers.
Woofer - Low Pass - 1400
Mid - High Pass - 1400, Low Pass - 5k
Tweeter - High Pass - 5k
12db/Octave High Pass
6db/Octave Low Pass
Any help/opinions are appreciated.
System:
Basically Stock
In process of upgrading
6db/Octave Low Pass
Active is the way to go if you want to do it right the easy way in a car. Passive to me is tonally more pleasing but the added time delay and slight EQ settings make it a winner.
Here is a rough guide all speaker and user preference dependent.
Also note that Eclipse a 3way setup is tweet-mid-sub and not tweed h-mid mid and sub as some might indicate.
DD guide
Subwoofers: 30hz Subsonic to 80hz Low Pass
Midbass: 80-250 hz
Midrange: 200-3,000 hz
Highrange: 3,000 hz and up
Careful with the tweeter though as not all tweeters are wide band many will only be happy at 5k up (also slope dependent).
Hope this helps.
I am on a 7200MKII so might be able to give you somewhat related advice if you are looking for any thing specific.
Loudness is no substitute for musicianship, and partial deafness is no badge of honor. I was once able to hear this advice.
Build Log>>>
http://www.stevemeadedesigns.com/board/ind...pid=672024&
New Build
Believe in the order
you need more than 4 channels to run 3way active
I was thinking of running the woofers in parallel bridged for 2 ohms & run the mid & tweeter w/ the crossover so they'll run 4 ohm on the other two channels. If that makes sense on here.
You need to add a 2 channel. And that factory LPF for the woofer is really 1400?? That sucks lol.
Yezzir ha. I was like wtf. So I was thinking of getting this - http://www.sonicelectronix.com/item_26897_PowerBass-Xtreme-XEX-23.html and run it in bandpass.
System:
Basically Stock
you still need more than 4 channels to run 3way active. also, bridging reduces the number of channels you have available. you need 6 channels of amplifier power to run 3 way active.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Id set the sub channel to flat. Many amps such as the sundowns will let you run active.
Build Log>>>
New Build
  • Who's Online   0 Members, 0 Anonymous, 1949 Guests (See full list)
