is it too much power?
pwrsubs901
you'll be fine. just do the big 3 too
whats the big 3
hint* google is your BEST friend...... thats where everyone finds it.....hundreds of pages describing it and how to's
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
do big 3 anyway.you just replace your current power wire from your alt to ur batt, n ur ground to block n ground to chassis ewith thicker wire. i went from charging under 12 wen playin to chillin 14 n up
Lucky Durango
Sony hu
4 croosfire 6.5mids
crossfire 600.1 mono amp
American bass 1280.4 mids and highs amp
aq hdc3 12
2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
don't replace any of the stock wiring, add too it.
x2 I ran under a thousand watts and had the big 3 done. It will make a difference. If you want to upgrade all the groundwork is done. No ripping out panels to replace small wire. Overbuild if budget and time allow. It will save you time later.
2005 Ford Focus zx4
AMT's and Planars
18" Infinite baffle
  • Who's Online   1 Member, 0 Anonymous, 1327 Guests (See full list)
