or a few screws.
ya. i usually fiberglass the inside so i dont use screws too much. but they are good too.
Edited by FCsteve
610EUROs
When we built my box at first all we used was 3/4 burch, brads, and tightbond. Wellll the side came loose and starting rattling about a week later. Some people say that I went a little crazy on it but, I fiberglassed the inside and predrilled, drilled in a 1 3/4" wood screw every 3"s on all overlapping sheets. Needless to say this box will never be broken. Here are some pics of the after.
Edited by EVLSPL
I also predrill/countersink MANY screws.
As long as you predrill it you shoulnd't have any splitting issues.
Liquid nails is ok as a "sealant" on the inside edges, just like silicone or caulking, but a BONDING wood glue is best for the actual construction. The diff between Construction and interior sealing should be noted-and if your measurements and CUTS are "true" enough, you shouldn't need interior sealant, the glue along a straight edge will seal perfectly.
Be careful using silcone to seal the interior and make sure it's completely CURED before you install the subs because some silicones emit FUMES as they cure that are BAD for FOAM surrounds on subs.
Edited by LSN2meBoom916
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
looks like drywall screws to me :D
  • Who's Online   0 Members, 0 Anonymous, 1412 Guests (See full list)
