Car died, wont start. Help =(
2.2 is a chain motor
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
Car did not start from jumping it at all, acted the same. Even acted the same when put on my 50a battery charger on engine start settings.
Can't be the timing belt because there isnt one. I've got my money on a short somewhere, just weird i happened on a perfectly smooth road going 15 mph
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
Check your main fuses in the engine compartment. There arent too many electrical components that will just stop the car all together. If your fuses check out test for spark at one of the plugs...
do your hear the fuel pump kick in when you turn the key ?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
3 questions.. when it died did it sputter almost like it wasnt getting gas and then it fell on its face and will not turn over now? di you getting a cel? and last is it cranking and not starting or does the starter not crank/engage...
I'll test fuses out tomorrow, its dark out tonight.
Doubt its the fuel pump and I can't check spark plugs since my engine wont turn over.
Honestly I'm not sure how it died, I just looked down and seen my rpm gauge was at zero. Didnt feel any sputter. No CEI, and the starter engages but can't turn the engine over which made it seem like a low battery.
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
The problem with low battery theory is that your car will run without the battery. Your alternator is what keeps the car running.
But if it was alternator, the jump start should have gotten it at least started. (assuming decent cables).
In the rare event that you alternator/battery and starter all failed at the same time would just be near impossible (buy a lotto ticket if this is the case).
The fact that it wont even turn over with a jump start is concerning.
Could be a bad ignition switch.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
So with a charged battery the car will start and run, but only for a short time? Check the alt bro, you may have just bought a new battery for no reason. :ehh:
I wish it were that simple, it simply wont start at all! Been looking for a good excuse for a new alt :pardon:
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
i didnt mean it was a fuel pump i just asked if acted/felt like it wasnt getting gas.. i ask this cuz one of the coils might be cracked or toasted and its grounding out on the motor.. if so it wont run or start or nothing.. it would be grounding out and shutting down the electrical system.. when ive diagnosed this prob before most people will say it was running fine and just fell on its face like it wasnt getting gas
