Sub barely moves?
Hopefully you it All the same siZe fuses if you got new ones... Had the sAme problem ended up being my remote wire. Most likely not the problem by try touching a wire from your power output to the remote see if it turns on without going into protect don't leave it there just give t a touch. If it turns on could most likely be ur remote wire why it's not turning on. Like I sAid most likely not that but just a last attempt to save your amp. Gl mAte
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
Hello
I'm having the same problem as you.
2 Kicker CVR Dual 2ohms and SSL Amp.
1 month ago it was excelent just needing more power. Than i put a aux battery and change the subwoofers wire.
Then the problem starts.
The sound it's to weak, i need to set the gain, bass boost and LPF to the half at least. But the sound it's not the same as before.
Already change the RCA, still the same.
Phase is ok.
check "subwoofer wire", might have installed it improperly
Hammerdown... 1%
it's ok. It was changed 2 times.
On the amp, sub output i can't tighten the screw on the positive. That could be the problem?
Well my amp is on its way back to AQ right now lol but i got new rcas and tested on this new amp i got from a friend.
I do have a quick question though. This temporary amp i got is a 2channel 200w amp (very old amp) and i got it hooked up and when i crank the volume up the power light on the amp goes off then back on with the bass. is this because its clipping or what. I have the gains like 1/4.
Fi X12
AQ750
Pioneer DEH-6300B h/u
  • Who's Online   1 Member, 0 Anonymous, 1262 Guests (See full list)
