what type of electrical would i need to run 2 T1500s?
have a kinetik 600 and 1800
2/3 big 3 done (going to finish the third)
0 gauge
going to fix my ground in rear bank to 0 gauge
what else might i need?
A new alternator
Ye dig, getting loud off little :D
(2) AQ HDC3 12
AQ 2200D - Replaced it, Works great
AQ4x90
JBL 662s 2 ways
(2)XS 5100r under the hood & A 170amp alt
If your car dies, then your electrical support needs improvement :P
wish i was more familiar with the Kinetik line.
More box builds
I'm with captain stupid.
adding batteries can only do so much on a stock alternator..x2 on a new alt..less strain on your batts and less chance of damaging equipment due to voltage drops
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
why would i need a new alternator? cant i just add batteries?
No matter how many batteries you have you still to charge them, a H/O alt will take the brunt of the power and you're not at full tilt it'll be able to charge those batteries you have
2011 Mitsubishi Outlander
Sony 712
Soundqubed HDS208
Alpine MRV-M500
Transmission line enclosure
Soundqubed wiring
Knu rca
XS Power battery
CNF terminals
depending on where you go on how much a alternator will cost.. there is MECHMAN..SINGER alts dc power.. dbelectrical
company on ebay called HI AMPS..
i would do a 200 or 220 amp alt using them 2 batteries u already have..and ADD another 1800... 1 more run of 0 gauge and ull be set for sure
