nbshazeezee Posted December 10, 2011 Report Posted December 10, 2011 I have this wired at 2ohms with a HDC3 on it, Its clipping almost all the time according to the remote indicator. Can yall throw me some advice? Ye dig, getting loud off little (2) AQ HDC3 12 AQ 2200D - Replaced it, Works great AQ4x90 JBL 662s 2 ways (2)XS 5100r under the hood & A 170amp alt
Guest Posted December 10, 2011 Report Posted December 10, 2011 that light isnt 100% accurate, just a heads up. but what do you mean its clipping all the time. like if the knob is all the way down or up it clips regardless? all that knob is is a gain reducer.
nbshazeezee Posted December 10, 2011 Author Report Posted December 10, 2011 i probably dont have the filters set right, but its clipping on the higher 40's mostly, doesnt really clip when its too low. But I am not able to give it the gain i should be able to give it without its clipping. Im giving it like half gain at 2ohms, and its clipping Ye dig, getting loud off little (2) AQ HDC3 12 AQ 2200D - Replaced it, Works great AQ4x90 JBL 662s 2 ways (2)XS 5100r under the hood & A 170amp alt
pa-pa-platypus Posted December 10, 2011 Report Posted December 10, 2011 how did you set ur gains? and 2 ohms really doesnt make a huge difference... a clipped signal is a clipped signal This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
matt14 Posted December 10, 2011 Report Posted December 10, 2011 It doesnt matter if you wire to .5 or 8ohm. When your set your gain, your done. The clipping indicator is not accurate from what i understand. Ive heard of people tuning with the DD1 and the clip light on there knob stays on all the time. Find someone local how has a DD1 or at least a o-scope to help set your gains, or buy a DD1. Its really a good investment. 2006 GMC YukonPioneer HU SHCA ran throughout Crescendo BC3500 One 18 AA Mayhem in a 4th order ZED Levithian 6 channel Rainbow Dual 6.5 comps ran Activehttp://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
icewall Posted December 11, 2011 Report Posted December 11, 2011 I have a similar situation with all my aq amps. seems like they should put out more power before they clip, very strange. btw, thats with or without a scope and with or without the remote hooked up. (tried it all, including wiring from .25 to 4 ohms and everything in between) (owned a lot of amps over the last 10 years but first time I had this problem and I own 3 aq1200d's so its not some fluk)
AMI CUSTOMS Posted December 12, 2011 Report Posted December 12, 2011 If the light is blinking it isn't clipping just giving you a warning, if the light is on solid then you are clipping. Mine are dead on with my oscope. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
t-money Posted December 12, 2011 Report Posted December 12, 2011 I have a similar situation with all my aq amps. seems like they should put out more power before they clip, very strange. btw, thats with or without a scope and with or without the remote hooked up. (tried it all, including wiring from .25 to 4 ohms and everything in between) (owned a lot of amps over the last 10 years but first time I had this problem and I own 3 aq1200d's so its not some fluk) i would look into the box if you arent happy with the output. maybe it isnt the amp. 2002 ford focus hatch pioneer DEH-P8400bh infinity kappa 6.5 components front and rear XS Power D1200 Shuriken BT-100 audioque 120.4 2 15 inch audioque HDC3 D2 2 audioque 2200d big 3 mechman 220a alt with external regulator 479-418-3056
TeamHT Posted December 12, 2011 Report Posted December 12, 2011 If the light is blinking it isn't clipping just giving you a warning, if the light is on solid then you are clipping. Mine are dead on with my oscope. Mine also have been pretty close. I thought they were off at first until I realized a solid light indicated clipping and not the light period. Tell me...does this smell like chloroform to you?
