can someone explain box tuning on torres plz
imj having trouble understanding the port portion of torres calculator. im trying to build a box for a vvx 8 n tune to 32 hz. can some explain to me what the height width n length corrolate to. like is it how deep in the box the port is going including the bend in. how wide from side to side or? or how high it is from box outer wall to port wa
Lucky Durango
Sony hu
4 croosfire 6.5mids
crossfire 600.1 mono amp
American bass 1280.4 mids and highs amp
aq hdc3 12
2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
They're just internal dimensions of your desired port.
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
height and width give you the surface area of the port. the length is what goes into the box, which is also what tunes the box to different frequencies.
thank you. so how do you calculate the bend in the box?just like from top to bend is this long then bend to end is this long?
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
so with three common walls?
and y does it not calculate tuning without putting in a diameter?
Lucky Durango
Sony hu
4 croosfire 6.5mids
aq hdc3 12
Because that if for round ports
