D-train-13k Posted December 13, 2011 Report Posted December 13, 2011 i have idle problems when the truck sits in idle for a long time. basically in drive gears the idle wil drop down to just ove 500 rpm. and it basically sounds like its cammed out. sputtering to stay on. then when i put it in park or neutral it rises up to the normal rpm but it still runs a little rough. then when i begin driving sometimes ill push the gas pedal and it will drop below 500rpm and sputter then itll go. when its driving around it runs great. youd never know it has a problem. so my question is what can cause problems like this. im pretty familiar with vehicles and how they work. but im terrible at diagnostics. it seems like it could be the idle air control valve. or maybe a sensor of some kind. thanks for the help The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
Loslam Posted December 13, 2011 Report Posted December 13, 2011 Perhaps you're out of time on your cam? or a bad timing sensor I know for my GM it took a computer to tell you what degree, and rotating the distributor CCW or CW to advance or retard the timing. For my truck -2 to +2 degrees was acceptable. 1997 Chevrolet Silverado Extended Cab, 350 Vortec Things to come at some point... Build Log: http://www.stevemead...2200ds-133-ohm/
POPLERO Posted December 13, 2011 Report Posted December 13, 2011 I have a 2002 ford f150 5.4 and had a very similar problem.. found that it was a bad air lifter and would get stuck and tend to mess with rpms at idle and such.. might look into it. 2008 TBSS Black Granite Alpine CDA-117 Clarion EQS746 AudioQue Supertweets @ dash Alpine DDT-s30 @ b pillars Alpine SPR-60c @ front doors Alpine SPR-60 @ rear doors Alpine PDX-f4 Second Skin DampPro KNUkonceptz Wiring DCpower 270amp alt Optima YT underhood *temp Two15DCxls Hifonics bxi2610 *temp saz4500 and 4 xp3000s coming soon.
805HECTOR9 Posted December 13, 2011 Report Posted December 13, 2011 i have an 03 f150 and that kind of happens but for me its mostly when i first start it up the rpms go low like if its just about to shut off and kind of sounds as if im running out of fuel then rises to normal.? yea but i dont know
kalaps Posted December 13, 2011 Report Posted December 13, 2011 I have had the same problem and it was my spark plugs you might want to Check that out
01VWGREENMACHINE Posted December 13, 2011 Report Posted December 13, 2011 I have had the same problem and it was my spark plugs you might want to Check that out check your maf sensor, O2 sensors, pluggs and coil system wether its coil packs or cap and rotor sounds like something along those lines http://www.stevemead...f-system-build/ 2001 VW GTI with a 1.8T motor BIG 3 Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS RF T1500-BDCP (running at 2 ohm) RF T400.4 RF T1 D212 x2 (in ported box) RF 1/0 TO 4 GAUGE distribution block x 2 all stinger wires 200a alternator (SINGER ALT) RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear) KINETIC HC 800 BATTERY (Front) KINETIC HC 1200 BATTERY (BACK) 120ft of 1/0 stinger blue and clear matt 20ft of 4 gauge stinger blue and clear matt 30ft of 8 gauge stinger blue and clear matt 100ft of 12 gauge stinger speaker wire black
Keith77 Posted December 13, 2011 Report Posted December 13, 2011 what year is it? Check engine light on? Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born. My penis is bigger than your penis I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
D-train-13k Posted December 13, 2011 Author Report Posted December 13, 2011 I have had the same problem and it was my spark plugs you might want to Check that out check your maf sensor, O2 sensors, pluggs and coil system wether its coil packs or cap and rotor sounds like something along those lines spark plugs are fairly new. and o2 sensors have been bad for a while. i just cant read my obd2 plug to get the codes. im just trying to rule out the expensive stuff such as the coil packs. i know those are likely to go bad in fords. what year is it? Check engine light on? its a 2000 4.2 check engine light is on. but that only refers to the exhaust system as far as i know. i know the o2 sensors are going bad. but i dont have the money to replace all four. anyways. thanks for the help guys. i have a vaccume leak just under the throttle body so im going to start there and replace the hose from there to my pcv valve. as well as replace the valve. i want to start with the cheap stuff then move on up. its about time to start replacing alot of stuff anyways. EDIT: this problem has just occured. ive had bad o2 sensors for a while. as well i have just taken off the tranny and replaced all the fluid and fly wheel. im pretty sure its not a transmission problem because it runs rough in neutral and in park. just having the load of the tranny is making the problem stand out more. The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
D-train-13k Posted December 13, 2011 Author Report Posted December 13, 2011 Perhaps you're out of time on your cam? or a bad timing sensor I know for my GM it took a computer to tell you what degree, and rotating the distributor CCW or CW to advance or retard the timing. For my truck -2 to +2 degrees was acceptable. im hoping that when i replaced the flywheel i didnt off the timing. seeing as how i needed to turn the crank to get the bolts out The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
crispy_chick3n Posted December 14, 2011 Report Posted December 14, 2011 Perhaps you're out of time on your cam? or a bad timing sensor I know for my GM it took a computer to tell you what degree, and rotating the distributor CCW or CW to advance or retard the timing. For my truck -2 to +2 degrees was acceptable. im hoping that when i replaced the flywheel i didnt off the timing. seeing as how i needed to turn the crank to get the bolts out unless your timing belt/chain was off or broken you shouldnt have thrown your timing off. it almost sounds like a fuel issue. check the vaccuum lines going to the fuel pressure regulator. if there are any cracks or breaks, replace it. also it couldnt hurt to throw a new fuel filter on it. This page is crispy_chick3n approved. © crispy_chick3n inc
