Which way should I fire my sub and my port in a extended cab truck non back seat it's a hdc3 15 if it matters also which side port
And sub?
Thanks in advanced
"SilveradoGoesBang"
http://www.stevemeadedesigns.com/board/topic/155256-silveradogoesbang-box-done-take-notes-on-bracing/
2 FI BTL 18's
CT Sounds 7k
2013 MidwestSPL Finals Xtreme 3 - 1st Place
Maybe its because I shouldn't be waking up at 4 in the morning my time and checking SMD...but I'm confused. Extended cab non back seat? Where is the enclosure? Enclosure specs? And what's your goal?
Sub box is where the back seat use to be and daily tuned to 35 and box will be built to specs for subs
"SilveradoGoesBang"
2 FI BTL 18's
CT Sounds 7k
Sub up. Port up
How do the Japanese feel about bass?
You know that since 03/11/11
Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.
im pretty sure the op wont even notice if it gets even smaller.
Refs - Pstone11, porksoda, coleman
alot of people have luck with sub up ported towards the passenger side with aeros.. some do towards the driver side and get better results.. you could try both with the same box really lol just spin it..thats what i would with 1 15 just my .02 tho
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
Passenger
Edit......oops
Edited by carlosg_313
My truck sounded better subs of port drivers side and im running the same setup your trying to do.
lol
or you can just start hooking shit up together and blow up speakers and your amp
