first off i haven't had any problems with my amp its a rf t1500bdcp and i have 2 rf T1d212's running at 2 ohm's.
problem is every so often it will cut out for about 10 seconds. amp is not getting hot at all, the grounds are all good at 0.1 ohm is all im getting with my volt meter. its getting plenty of power so im stumped any help would be awesome.
thanks in advance!!
see my build for more build info and pics in my sig below
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
thanks in advance!!
When mine did that was when I had a 4 gauge wiring kit with 2 kenwood performance series 1,800 watt amps. I Went to a 0 gauge wiring kit and it stopped. And it only did it when I was hitting hard. But, when I was just cruising and had it on low it was fine. If you already 0 gauge then idk. Bad wire maybe??
Current system (still building) 2 kicker 12" dcvr in factory kicker ported box, Rockford Fosgate 1200.1 Amp, Kenwood ddx-470 ddin radio, Rockford Fosgate 0 Gauge wiring, Rockford Fosgate punch 6X8 2 way speakers.
thanks in advance!!
well not sure if thats it but i have all 1/0 stinger wire exceot the last 12 inches from the dis block to the amp. the amp only has 4guage wire inputs
BIG 3
RF T400.4
all stinger wires
How low of a voltage drop do you have at full tilt? Got a h/o alt? His manny bats?
200 amp ho singer alt runs at 14.1 it doesnt see 13 at all
dual batts stock up front and hc800 in rear
Edited by 01VWGREENMACHINE
BIG 3
RF T400.4
all stinger wires
check all connections, one may be loose...
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
been there done that
BIG 3
RF T400.4
all stinger wires
could it be the fact that my woofers are blown?? the coils are burnt
BIG 3
RF T400.4
all stinger wires
Yes.^ if there shorting out or something.
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
i assume the problem was fixed.
