01VWGREENMACHINE Posted December 15, 2011 Report Share Posted December 15, 2011 first off i haven't had any problems with my amp its a rf t1500bdcp and i have 2 rf T1d212's running at 2 ohm's. problem is every so often it will cut out for about 10 seconds. amp is not getting hot at all, the grounds are all good at 0.1 ohm is all im getting with my volt meter. its getting plenty of power so im stumped any help would be awesome. thanks in advance!! see my build for more build info and pics in my sig below Quote http://www.stevemead...f-system-build/ 2001 VW GTI with a 1.8T motor BIG 3 Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS RF T1500-BDCP (running at 2 ohm) RF T400.4 RF T1 D212 x2 (in ported box) RF 1/0 TO 4 GAUGE distribution block x 2 all stinger wires 200a alternator (SINGER ALT) RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear) KINETIC HC 800 BATTERY (Front) KINETIC HC 1200 BATTERY (BACK) 120ft of 1/0 stinger blue and clear matt 20ft of 4 gauge stinger blue and clear matt 30ft of 8 gauge stinger blue and clear matt 100ft of 12 gauge stinger speaker wire black Link to comment Share on other sites More sharing options...
basshead8569 Posted December 15, 2011 Report Share Posted December 15, 2011 first off i haven't had any problems with my amp its a rf t1500bdcp and i have 2 rf T1d212's running at 2 ohm's. problem is every so often it will cut out for about 10 seconds. amp is not getting hot at all, the grounds are all good at 0.1 ohm is all im getting with my volt meter. its getting plenty of power so im stumped any help would be awesome. thanks in advance!! see my build for more build info and pics in my sig below When mine did that was when I had a 4 gauge wiring kit with 2 kenwood performance series 1,800 watt amps. I Went to a 0 gauge wiring kit and it stopped. And it only did it when I was hitting hard. But, when I was just cruising and had it on low it was fine. If you already 0 gauge then idk. Bad wire maybe?? Quote Current system (still building) 2 kicker 12" dcvr in factory kicker ported box, Rockford Fosgate 1200.1 Amp, Kenwood ddx-470 ddin radio, Rockford Fosgate 0 Gauge wiring, Rockford Fosgate punch 6X8 2 way speakers. Link to comment Share on other sites More sharing options...
01VWGREENMACHINE Posted December 15, 2011 Author Report Share Posted December 15, 2011 first off i haven't had any problems with my amp its a rf t1500bdcp and i have 2 rf T1d212's running at 2 ohm's. problem is every so often it will cut out for about 10 seconds. amp is not getting hot at all, the grounds are all good at 0.1 ohm is all im getting with my volt meter. its getting plenty of power so im stumped any help would be awesome. thanks in advance!! see my build for more build info and pics in my sig below When mine did that was when I had a 4 gauge wiring kit with 2 kenwood performance series 1,800 watt amps. I Went to a 0 gauge wiring kit and it stopped. And it only did it when I was hitting hard. But, when I was just cruising and had it on low it was fine. If you already 0 gauge then idk. Bad wire maybe?? well not sure if thats it but i have all 1/0 stinger wire exceot the last 12 inches from the dis block to the amp. the amp only has 4guage wire inputs Quote http://www.stevemead...f-system-build/ 2001 VW GTI with a 1.8T motor BIG 3 Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS RF T1500-BDCP (running at 2 ohm) RF T400.4 RF T1 D212 x2 (in ported box) RF 1/0 TO 4 GAUGE distribution block x 2 all stinger wires 200a alternator (SINGER ALT) RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear) KINETIC HC 800 BATTERY (Front) KINETIC HC 1200 BATTERY (BACK) 120ft of 1/0 stinger blue and clear matt 20ft of 4 gauge stinger blue and clear matt 30ft of 8 gauge stinger blue and clear matt 100ft of 12 gauge stinger speaker wire black Link to comment Share on other sites More sharing options...
Dangrebel Posted December 15, 2011 Report Share Posted December 15, 2011 How low of a voltage drop do you have at full tilt? Got a h/o alt? His manny bats? Quote 1999 GMC Yukon, 6 PSI platform 5 18's, 4th order bandpass by BHE, Taramps, Link to comment Share on other sites More sharing options...
01VWGREENMACHINE Posted December 16, 2011 Author Report Share Posted December 16, 2011 (edited) How low of a voltage drop do you have at full tilt? Got a h/o alt? His manny bats? 200 amp ho singer alt runs at 14.1 it doesnt see 13 at all dual batts stock up front and hc800 in rear Edited December 16, 2011 by 01VWGREENMACHINE Quote http://www.stevemead...f-system-build/ 2001 VW GTI with a 1.8T motor BIG 3 Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS RF T1500-BDCP (running at 2 ohm) RF T400.4 RF T1 D212 x2 (in ported box) RF 1/0 TO 4 GAUGE distribution block x 2 all stinger wires 200a alternator (SINGER ALT) RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear) KINETIC HC 800 BATTERY (Front) KINETIC HC 1200 BATTERY (BACK) 120ft of 1/0 stinger blue and clear matt 20ft of 4 gauge stinger blue and clear matt 30ft of 8 gauge stinger blue and clear matt 100ft of 12 gauge stinger speaker wire black Link to comment Share on other sites More sharing options...
mbdblue Posted December 16, 2011 Report Share Posted December 16, 2011 check all connections, one may be loose... Quote AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco Link to comment Share on other sites More sharing options...
01VWGREENMACHINE Posted December 16, 2011 Author Report Share Posted December 16, 2011 check all connections, one may be loose... been there done that Quote http://www.stevemead...f-system-build/ 2001 VW GTI with a 1.8T motor BIG 3 Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS RF T1500-BDCP (running at 2 ohm) RF T400.4 RF T1 D212 x2 (in ported box) RF 1/0 TO 4 GAUGE distribution block x 2 all stinger wires 200a alternator (SINGER ALT) RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear) KINETIC HC 800 BATTERY (Front) KINETIC HC 1200 BATTERY (BACK) 120ft of 1/0 stinger blue and clear matt 20ft of 4 gauge stinger blue and clear matt 30ft of 8 gauge stinger blue and clear matt 100ft of 12 gauge stinger speaker wire black Link to comment Share on other sites More sharing options...
01VWGREENMACHINE Posted December 16, 2011 Author Report Share Posted December 16, 2011 could it be the fact that my woofers are blown?? the coils are burnt Quote http://www.stevemead...f-system-build/ 2001 VW GTI with a 1.8T motor BIG 3 Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS RF T1500-BDCP (running at 2 ohm) RF T400.4 RF T1 D212 x2 (in ported box) RF 1/0 TO 4 GAUGE distribution block x 2 all stinger wires 200a alternator (SINGER ALT) RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear) KINETIC HC 800 BATTERY (Front) KINETIC HC 1200 BATTERY (BACK) 120ft of 1/0 stinger blue and clear matt 20ft of 4 gauge stinger blue and clear matt 30ft of 8 gauge stinger blue and clear matt 100ft of 12 gauge stinger speaker wire black Link to comment Share on other sites More sharing options...
MIKE-2U Posted December 18, 2011 Report Share Posted December 18, 2011 Yes.^ if there shorting out or something. Quote 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd Link to comment Share on other sites More sharing options...
MIKE-2U Posted December 26, 2011 Report Share Posted December 26, 2011 i assume the problem was fixed. Quote 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd Link to comment Share on other sites More sharing options...
