I can get close to a 4 ohm reading from and positive terminal to any negative on this sub. If its dual VC wouldn't I get a 0 ohm reading from one of the positives to one of the negatives?
so you are testing it while its wired like above, correct?
Correct. Unless the SVC has the same connectors as the DVC I'm pretty sure it's the DVC. It has the screws for two sets of VCs
I think you've got a SVC Thunder 9500.
by the sounds of it he has two negatives and two positives so i dont think that would be correct.
Post up some pictures and we can better assist you.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
no, because when one of them is pos to neg, that is part of wiring a sub in series.
just do what is said.
Positive from coil 1 to positive on coil 2, then negative on coil 1 to negative on coil 2. Then put your meters positive prong into the positive on coil 2, then the negative prong to the negative of coil 2. it should read 1.8-2.2 ohms. If it reads ~3, connect the two prongs of the meter together and wait and see what ohm load comes up. report back with these two numbers.
PICS OF SAID SUB WOULD HELP.
EDIT: some SVC subs have two positives and negative to help wiring multiple subs together so you dont have to jam 2 10ga wires into 1 10ga terminal.
Edited by ChevyBoy95
look on the bottom of the sub
if the model ends in 22 or 44 its a dual voice coil
if the model ends in 02 or 04 its a single voice coil
re of single coil is 3.66
re of dual coil is 3.42
Edited by Decaf
Well I think that solves my problem. It's a sticker on the sub under the connectors and ends in 04. Well that blows donkey dick. Thanks for the help everyone
  • Who's Online   0 Members, 0 Anonymous, 877 Guests (See full list)
