yes with it off will give you your battery voltage and will let you know if your battery is holding a good charge and then when you check it while running it will tell you what voltage you alternator is recharging your battery at
if the battery and alternator check out fine you can always re grease the window track and clean the connections on the window motor i have seen them get corroded and cause a bunch of electrical resistance.
Most cars will do this.
My explorer did it too with a brand new alt and battery.
2015 Honda Civic LX 4dr | 110k miles | Stock
1996 GMC Yukon SLT 4dr 4wd | 260k miles | JVC Head-unit
Only time that my lights dimmed is when my alternator was about gone or I had a bad connection on the alt it self. Check all connections or take your car to a part shop. Ones by me do a free alt test. And thats with it on the car....
Current system (still building) 2 kicker 12" dcvr in factory kicker ported box, Rockford Fosgate 1200.1 Amp, Kenwood ddx-470 ddin radio, Rockford Fosgate 0 Gauge wiring, Rockford Fosgate punch 6X8 2 way speakers.
My lights dim when I use my power Windows.
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
  • Who's Online   1 Member, 0 Anonymous, 543 Guests (See full list)
