How much does the cone of a fi 18" bl and 18" sp4 bounce up to?
Vooloco
If it was me, i would just run 2 sa-12s on that amount of power. That amp doesnt draw much current, my bro ran his on a stock front bat, and a stinger 2150 with a 145 alt and his voltage stays above 13.5 gains set with dd-1. So a good front battery and decent rear will be all you need for that amp with that alt.
those subs are only rated at 600 RMS tho.
They can ride double the power each all day. My buddy has 2 sa-15s on a Saz-2500
BASSHEADS UNITE
There also one of the best woofers for what they are rated
BASSHEADS UNITE
The are "rated" at 600 rms, but many have put 1k+ to them and they handle it fine. Plus after all the imp rise, you are lucky to get 2.2k out of that amp.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
(2) 12" fi bl - (2)48000mm^2 * 18mm = 1728000mm^3
(1) 18" fi bl - 121000mm^2 * 18mm = 2178000mm^3
vd isnt everything, but in this example you can see that the 18 displaces more air than 2 12s because of its larger cone area.
1324421939[/url]' post='1808094']
I saw that coming. But thats not the case
Tell me then, what would move more air?
1 18 with 20mm Xmax, or 2 12s with 20mm xmax each
The 2 12s will be louder
1324421763[/url]' post='1808090']
1324421450[/url]' post='1808081']
Technically yes
It is Slightly smaller yes, but the Xmax is they key
Say a 18 had 20mm xmax, but 2 12s had a xmax of 20mm each.
With similar cone areas, the 2 12s win because more air is moving, thus being louder.
you just contradicted yourself. if they both have the same xmax, which doesnt really matter anyways, yet the 18 has more cone area, the 18 will move more air. 20mm is 20mm. if you have two woofers it doesnt all of a sudden go up to 40, it stays at 20.
what you just said is like saying i have a 1000w stereo because my woofer is 500w and my amp is 500w. it doesnt work like that
The 18 - more volume displacement. Although the 12s have more motor force.
Depends on the motor/coils used, but yes the 12's should have more motor force.
Just for the fun of it and to possibly help you (StephenAudio) with your basic math skills here are what the 12's would need for xmax to match the 18 at 20mm.
254.47x20mm = 5089.4/226.19 = 22.5mm
Xmax/Xmech isnt the end-all-be-all though.
Anyways, I vote 12's.
Hammerdown... 1%
you should be using sd not the area of a 12/18" circle.
if you are multiplying by the same xmax whichever is the largest cone area will have more vd. again tho, this doesnt determine which will be louder, just which can displace more air on all notes.
sd is cone area, assuming proper measurements were made. The numbers in this thread are all pretty much junk though. Cone area is a linear measurement btw, dont measure the depth of the cone and calculate it as a true cone, just as a flat piston.
Hammerdown... 1%
Technically yes
Do you enjoy talking out your ass?
I hope you don't offer advice very often, I feel sorry for any one who listens.
OP, you want stereo and performance. Give up.
60Lbs woofer
20Lbs amp
100Lbs box
10Lbs wire
80Lbs battery
80Lbs battery
350Lbs
  • Who's Online   0 Members, 0 Anonymous, 628 Guests (See full list)
