bad voltage drop a sub amps
Help needed am running 2 warhorse 10k,mechman 270alt(biggest available n no dual brackets) 3+ runs of 0g and 3- runs to chasis up front and from chasis rear to battery bank.....at full tilt I'm reading 13+volts up front while the sub amps are seein below 11volts at the rear...help me out with opinions suggestions will appreciate them!
2004 trailblazer
4 FI BTL 18s
(2) DC 10.0k
xs power d3100s
mechman 270
158.2 @41
Damn 2 warhorses on a 270a. You will need a lot of batteries.
What type of batteries do you have now and how many?
EDIT: And a good battery charger.
Edited by brownm3
Need more alt power for sure
What kind of batts and how many
Pretty sure kicker recommends atleast two alts to run just ONE warhorse..
Edited by RickyFriery97
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
its a trailblazer there aren't any brackets available for a dual set up...am runnin (8)d3100 they recommend 4 per amp (6) optima yellows since I had them already but they also asked for 400amps of alt per amp which I cnt supply because of the type of vehicle
2004 trailblazer
4 FI BTL 18s
(2) DC 10.0k
xs power d3100s
mechman 270
158.2 @41
But I did do some diagnosing n replacing and saw a heated ground wire in the batt bank...seems like it had a bad connection somehow and began creatin some heat..2morrow ill d some testn n monitorin the volts to see if the problem was corrected
2004 trailblazer
4 FI BTL 18s
(2) DC 10.0k
xs power d3100s
mechman 270
158.2 @41
  • Who's Online   0 Members, 0 Anonymous, 1499 Guests (See full list)
