I have a single 12 inch HDC 3 subwoofer. I want to get louder. but i like the single woofer setupd. MY amp is a AQ 2200. run great. My question is what should i do? there are a few things that i want to do. What would yall rather see? Should i get another HDC3 12? should i sell it and get 2 skar 12's? Or should i buy a 15 suboowoofer with greater power handling. Like a 15" modified DC from Techforce or a BTL or a DC XL or level 5 ( when they are back) or an SP4.? so basicly. get another twelve, or go more power with a a single 15
Ye dig, getting loud off little :D
(2) AQ HDC3 12
AQ 2200D - Replaced it, Works great
AQ4x90
JBL 662s 2 ways
(2)XS 5100r under the hood & A 170amp alt
i vote, 27 18's
2006 Nissan Z Track.
My Feedback Thread
i vote, 27 18's
Alex, can you ever give me a serious opinion?
(2) AQ HDC3 12
AQ4x90
JBL 662s 2 ways
its a toss up. just adding cone area properly can gain output, assuming its in a way to avoid cancellation. adding a second 12 is more cone than a single 15, but efficiency and box design can also greatly increase output, even if you went to a single 15, especially if you move to a sub with more motor strength. there are instances that even without a change in power, simply more motor force can help spl potential. not always, but i have seen it. my personal opinion, i like more cone area. id go with 2 12s, maybe even 2 other ones that can efficiently make use of the 2200 watts you have. 2200 watts can produce some respectable spl in the right design.
2 12s have more cone area then 1 15.
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
power matters too man!
(2) AQ HDC3 12
AQ4x90
JBL 662s 2 ways
1 15 if you are not changing amps. I have had lower power 15s on a 1k amp, then went to a level 4 15 on the same amp and was louder, way louder (in reality this doesn't have much relevance because all applications are different, but in my case 1 higher power 15 was yummy.)
I love the single woofer setups. but what to get is the question
(2) AQ HDC3 12
AQ4x90
JBL 662s 2 ways
