Im in need of some help with finding the best amplifers for my subs. First off i have 4 12" JL W7's. they will take 2k power easy but looking for something in the ball park of around 1.5-1.6k power to each sub. My predicament comes in the form of that these subs are only a single 3 ohm vc. These are my option, along with some questions.
First, I try and find 1-2 amps that will power all them at .5-.75 ohm. What amps will do that and be efficient?
Second, do i go with 4 2 channel brigable amps? The only issue i see here is that most amps are 4ohm brigded. Whats the likly hood of the amps failing with a 3 ohm load?
Thank You for your time and help!!
Jordan
Audioque 3500, wire all the subs in parallel.
I hope you have the electrical to back this up
Good luck trying to power each sub with 1.5k...
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
AQ3500.1 is definitely a nice option, wire it below 1 ohm should get you a nice power after rise anyway since it´s an underated amp :)
Really? Even thou theres no ratings for anything below 1 ohm? Just worries me sometimes not knowing if it will actually go that low concidering you put out that much money youd expect to get every rating possible you know...
Thank You
i def have the electrical to back it up but thats only 875 a sub, currently i have about 950ish per sub.
Thank you
It's 4300 watts at 1 ohm - you would be wiring at less then that. And its a pretty solid amp - I can see ~ 5000 watts out of it
If you want moar power, get a dc 7.5k or find a used JBL Crown a6000gti or something
Edited by SnowDrifter
Thank You
Depends on the amplifier, yes that aq3500.1 can play below 1 ohm if you have the electrical to back it up (wich you said you have) , that amplifier should MURDER ;)
Thank You
awesome! Thank You!
  • Who's Online   1 Member, 0 Anonymous, 1634 Guests (See full list)
