If you used the same dimension but made port bigger your net volume will decrease. Im not home but what's your net for both sides after all displacements.
32x6x30 Good luck.
so something like this
What's the specs on this one
same 35x50x19 port 33.5x6x29.5
I hope you have enough power to feed those subs, box is very small if you go with the measures you just gave, i would do a port 33.5 x 5.25 x 22 , that would raise your internal around 1.5 cubic feet with a 33 hz tuning, that should sound better than the smaller box with bigger port, that´s a C pillar wall????
Edited by fecupe2001
32x6x30 Good luck.
ok but how far i make the bend from the back wall 5.25 :drink40:
