impossible to tell you which will be better with X watts.
and the first part of the question doesnt even apply if you later ask which one is better with 1200 watts.
It would be a waste to get a sub that can take 3+ thousand watts to only put 1200 through it. You would be better off getting a lesser sub and putting the saved money into other thingd
I might upgrade the amp to a 2000 watt one in a few months.
Copper coil HDC would do well on 1200watts. Just because it can take more doesn't mean you have to feed it that much. I'd go on the big side for the enclosure if you go that route.
No idea what a BL is rated for, but I'm running an AQ1200 on the wife's Q with no issues.
3000 watts RMS? You'll blow both of those subs at that. AQ is rated at 1k and the fi bl is 1.5k.
The hdc3 can take well over 1k clean power daily.....
Many variables to that, box design, user's experience, etc. etc.
TDH FTW !!!
this..even if your throwing clean power at it if youre box design is off than you can still end up blowing the sub
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
  • Who's Online   0 Members, 0 Anonymous, 627 Guests (See full list)
