USAFBordeaux Posted December 31, 2011 Report Posted December 31, 2011 Hey there. Okay here's the specs 2008 Mitsubishi Lancer GTS 2x SA-12's D2 Box is tuned to 30hz Amp: TBD I've done the Big 3 upgrade now i'm just looking for an amp that's semi cheap but affordable ~300$ to spend for an amp Since the subs are D2 I would need a .5 ohm stable amplifier. Any suggestions? Quote no matter where I go, no matter what I do, no matter the choices I make... I will always have bass. Ba$$H34Ds unite. Audio Modifications Big 3 Upgrade
Socky Posted December 31, 2011 Report Posted December 31, 2011 audiopipe 3000D Quote Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz
deathcards Posted December 31, 2011 Report Posted December 31, 2011 any ho alt and extra batteries Quote skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
USAFBordeaux Posted December 31, 2011 Author Report Posted December 31, 2011 (edited) nope stock electrical. I believe the alt is 120 output the battery i have under the hood cost like 100$ from autozone. Edited December 31, 2011 by USAFBordeaux Quote no matter where I go, no matter what I do, no matter the choices I make... I will always have bass. Ba$$H34Ds unite. Audio Modifications Big 3 Upgrade
SkylarDunn Posted December 31, 2011 Report Posted December 31, 2011 If you only have $300 to spend, keep saving, you wont get anything worth a damn for that price. Save up enough for an alt, put that in, then save up $500 for a crescendo 3500 (i dont remember what they cost off hand). Quote Getting bass into the cabin of a W124 mercedes is impossible. Current setup: Temp 1999 panasonic HU rockford 300.2 for fronts rockford 200.2 for rears rockford 400.1 for sub Leaning towards a 8" in an exponential horn DAMN YOU GERMANS AND YOUR 5" SPEAKERS!
Jd1102 Posted December 31, 2011 Report Posted December 31, 2011 If you only have $300 to spend, keep saving, you wont get anything worth a damn for that price. Save up enough for an alt, put that in, then save up $500 for a crescendo 3500 (i dont remember what they cost off hand). why crescendo? Quote
SkylarDunn Posted December 31, 2011 Report Posted December 31, 2011 also, at 120a, you have maybe 1000w worth of usable amperage, at .5 on a .5 stable amp, with imp. rise maybe 600w for both subs. Quote Getting bass into the cabin of a W124 mercedes is impossible. Current setup: Temp 1999 panasonic HU rockford 300.2 for fronts rockford 200.2 for rears rockford 400.1 for sub Leaning towards a 8" in an exponential horn DAMN YOU GERMANS AND YOUR 5" SPEAKERS!
SkylarDunn Posted December 31, 2011 Report Posted December 31, 2011 If you only have $300 to spend, keep saving, you wont get anything worth a damn for that price. Save up enough for an alt, put that in, then save up $500 for a crescendo 3500 (i dont remember what they cost off hand). why crescendo? Because they're built well, priced well, and it uses the same board as the sundown 3500. If i was going to buy an amp, i'd buy one thats not going to blow its mosfets in a year (the audiopipe 3000 comes to mind, and its not even actually 1 ohm stable either) Quote Getting bass into the cabin of a W124 mercedes is impossible. Current setup: Temp 1999 panasonic HU rockford 300.2 for fronts rockford 200.2 for rears rockford 400.1 for sub Leaning towards a 8" in an exponential horn DAMN YOU GERMANS AND YOUR 5" SPEAKERS!
USAFBordeaux Posted December 31, 2011 Author Report Posted December 31, 2011 what about a 2ohm amp that's puts out 2000w? Quote no matter where I go, no matter what I do, no matter the choices I make... I will always have bass. Ba$$H34Ds unite. Audio Modifications Big 3 Upgrade
Jd1102 Posted December 31, 2011 Report Posted December 31, 2011 also, at 120a, you have maybe 1000w worth of usable amperage, at .5 on a .5 stable amp, with imp. rise maybe 600w for both subs. this isn't true he could have 20 millions batterys(just an expression) and have lots more power If you only have $300 to spend, keep saving, you wont get anything worth a damn for that price. Save up enough for an alt, put that in, then save up $500 for a crescendo 3500 (i dont remember what they cost off hand). why crescendo? Because they're built well, priced well, and it uses the same board as the sundown 3500. If i was going to buy an amp, i'd buy one thats not going to blow its mosfets in a year (the audiopipe 3000 comes to mind, and its not even actually 1 ohm stable either) what about aq, dc, many others? Quote
