Suggest an Amp for me please!!
USAFBordeaux
Hey there. Okay here's the specs
2008 Mitsubishi Lancer GTS
2x SA-12's D2
Box is tuned to 30hz
Amp: TBD
I've done the Big 3 upgrade now i'm just looking for an amp that's semi cheap but affordable
~300$ to spend for an amp
Since the subs are D2 I would need a .5 ohm stable amplifier.
Any suggestions?
no matter where I go, no matter what I do, no matter the choices I make... I will always have bass.
Ba$$H34Ds unite.
Audio Modifications
Big 3 Upgrade
audiopipe 3000D
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
nope stock electrical. I believe the alt is 120 output
the battery i have under the hood cost like 100$ from autozone.
Edited by USAFBordeaux
Ba$$H34Ds unite.
Audio Modifications
Big 3 Upgrade
If you only have $300 to spend, keep saving, you wont get anything worth a damn for that price. Save up enough for an alt, put that in, then save up $500 for a crescendo 3500 (i dont remember what they cost off hand).
Getting bass into the cabin of a W124 mercedes is impossible.
Current setup:
Temp 1999 panasonic HU
rockford 300.2 for fronts
rockford 200.2 for rears
rockford 400.1 for sub
Leaning towards a 8" in an exponential horn
DAMN YOU GERMANS AND YOUR 5" SPEAKERS!
also, at 120a, you have maybe 1000w worth of usable amperage, at .5 on a .5 stable amp, with imp. rise maybe 600w for both subs.
Current setup:
why crescendo?
Because they're built well, priced well, and it uses the same board as the sundown 3500. If i was going to buy an amp, i'd buy one thats not going to blow its mosfets in a year (the audiopipe 3000 comes to mind, and its not even actually 1 ohm stable either)
Current setup:
this isn't true he could have 20 millions batterys(just an expression) and have lots more power
why crescendo?
what about aq, dc, many others?
