Hello everyone!
As I was waiting for my HDC3 15" to ship (Coming next Thursday), I decided to put a little bump into my car. I bought a 18" Punch xlc and a sealed box to fill in on bass for the time being. I'm afraid to admit that i'm used to push terminals and i have no idea how to wire this damn thing..
This subwoofer is 8 ohm.
I have a Hifonics brz 1700.1, is there any way that i could hook this subwoofer to it @4 ohms? At 4 ohms, this amp does 600 watts. I know it's still a bit much, but i don't really care about the sub. I got it for about 50 bucks.
Anyways, here are some pics..
http://tinypic.com/r/qsqc21/5
http://tinypic.com/r/vhaic4/5
Thanks in advance everyone. A paint edit on the wiring would be fantastic :)
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
Thank you sir! Is this a duel voice coil subwoofer? I'm so lost on these old speaker wiring. All i've had have been alpine and they have all had push terminals..
(1) Mechman 240
TEAM NWSPL
155db outlaw
Well, so far the only option on the12volt has been to wire it at 8 ohms but my amp isn't stable at that impedence, is it? That's if this sub is single voice 8 ohm.
(1) Mechman 240
TEAM NWSPL
155db outlaw
Yes your amp is stable at the ohm, all you do is look at the white peice that the terminals are on, you should see a + or a -, wire it parallel, means positive to positive, negative to negative.
edit: looking at it, after i replied, looks to see one is a postive, the other side is a negative, since their is only one lead wiring come off the terminals. I would use a 9v battery and test to see which is the right phase.
Edited by Socky
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
I'm still confused on weither this is a single voice coil or duel voice coil subwoofer?
I really wish I could run this at a 4 ohm load on my amp but I have no idea weither I can or not.
(1) Mechman 240
TEAM NWSPL
155db outlaw
There is a red dot on one of the metal things. I'm assuming that's the positive side.
(1) Mechman 240
TEAM NWSPL
155db outlaw
You really can't tell if it's a single or dual? Knowing it's an old Rockford woofer, I assume it's a single 8 ohm. So no, you cannot wire it at 4 ohms.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
Well that's crappy :P
Hopefully it'll get a good 300 watts from my amp :P
(1) Mechman 240
TEAM NWSPL
155db outlaw
