I wouldnt do it with that big of a box, i would just run it at 2 ohm, maybe if the box was aroung 6-7 cubes then yea i would say go for it.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Well each sub is only going to be seeing 7cf if that makes a difference... They are separated, so its technically two 7cf enclosures. I apologize, I should have made that clear earlier.
Edited by ShAdOwSpEcTrUm7
oh, i thought you would only have 1 sub, but if its two, they should handle that power with ease, may i ask, what is your electrical that you have already?
Kenwood H/U
1/0 wire,
I have a 270 amp alternator (about 215 amps at idle), 4 XS Power D3100s and a Big Three upgrade using 2/0 wire.
The subs are 2000 RMS, and that amp does 4500 at 1 ohm.. So at .5 ohm it will probably do well over 6k if not more. Sundown only recommends it going down to 1 ohm.. I wouldn't risk that with a $2k amp. And I definitely wouldn't risk giving those subs 3k+ rms if they are only rated for 2k RMS. You should have got the dual 4 triple x's. If you can.. send them back and get the dual 4's!
  • Who's Online   0 Members, 0 Anonymous, 1753 Guests (See full list)
