ShAdOwSpEcTrUm7 Posted January 1, 2012 Report Share Posted January 1, 2012 Okay, I have two of the new RE XXX 18s and a Sundown SAZ-4500D. I have the electrical to run the amp at 0.5 ohms and would like to do so provided the subs can handle it... Would I be better off running them at 2 ohms? What do you guys think? Quote Link to comment Share on other sites More sharing options...
will77530 Posted January 1, 2012 Report Share Posted January 1, 2012 just run them at 2 ohms dont risk it if your not sure its a costly mistake if it goes wrong Quote Link to comment Share on other sites More sharing options...
TeamHT Posted January 1, 2012 Report Share Posted January 1, 2012 Details and specs to the enclosure? Quote Tell me...does this smell like chloroform to you? Link to comment Share on other sites More sharing options...
ShAdOwSpEcTrUm7 Posted January 1, 2012 Author Report Share Posted January 1, 2012 Details and specs to the enclosure? The enclosure is going to be 14cf after displacement tuned to 35hz with 17in^2 of port area per cf. Quote Link to comment Share on other sites More sharing options...
Socky Posted January 1, 2012 Report Share Posted January 1, 2012 I wouldnt do it with that big of a box, i would just run it at 2 ohm, maybe if the box was aroung 6-7 cubes then yea i would say go for it. Quote Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz Link to comment Share on other sites More sharing options...
ShAdOwSpEcTrUm7 Posted January 1, 2012 Author Report Share Posted January 1, 2012 (edited) I wouldnt do it with that big of a box, i would just run it at 2 ohm, maybe if the box was aroung 6-7 cubes then yea i would say go for it. Well each sub is only going to be seeing 7cf if that makes a difference... They are separated, so its technically two 7cf enclosures. I apologize, I should have made that clear earlier. Edited January 1, 2012 by ShAdOwSpEcTrUm7 Quote Link to comment Share on other sites More sharing options...
Socky Posted January 1, 2012 Report Share Posted January 1, 2012 oh, i thought you would only have 1 sub, but if its two, they should handle that power with ease, may i ask, what is your electrical that you have already? Quote Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz Link to comment Share on other sites More sharing options...
ShAdOwSpEcTrUm7 Posted January 1, 2012 Author Report Share Posted January 1, 2012 oh, i thought you would only have 1 sub, but if its two, they should handle that power with ease, may i ask, what is your electrical that you have already? I have a 270 amp alternator (about 215 amps at idle), 4 XS Power D3100s and a Big Three upgrade using 2/0 wire. Quote Link to comment Share on other sites More sharing options...
LoudBimmer Posted January 1, 2012 Report Share Posted January 1, 2012 I don't have any experience with this subs, but box seems to be way too big. Quote Link to comment Share on other sites More sharing options...
Mad_Mike Posted January 1, 2012 Report Share Posted January 1, 2012 The subs are 2000 RMS, and that amp does 4500 at 1 ohm.. So at .5 ohm it will probably do well over 6k if not more. Sundown only recommends it going down to 1 ohm.. I wouldn't risk that with a $2k amp. And I definitely wouldn't risk giving those subs 3k+ rms if they are only rated for 2k RMS. You should have got the dual 4 triple x's. If you can.. send them back and get the dual 4's! Quote Link to comment Share on other sites More sharing options...
